Box tuning with a Aero port
BriAnyaKno
I am making my next box build for a 15 with a aero port. the setup will be sql oriented running 2k tops. I have built a slot port box at 30hz sounds amazing for my 10". I have been told aero ports move more air but sound higher. So i am wondering whats my best bet on tunning to make it equal to a 30hz slot port. im thinking i would probably have to go 28hz maybe 25hz lowest. also would pollyfill help with the noise the 15 will be seeing 3.11cuft. the driver is a custom build wit t3 tss motor pierce audio products wmd2 coil and custom softparts. should be able to take 2kwrms daily with music without a problem. wont have ts specs/parameters for a week or two
-BriAn
12" RD Audio Alpha v2 with PAP softparts. 3"ww 8layer al vc
Recoil RED 1000.1
Audiopipe 0 gauge wiring kit
Kinetik hc600
5 Farad Capacitor
2.26cuft slot ported box tuned to 30hz
(bbp6 says its 37hz 12volt says 30hz)
Just tune the areaport like a normal slot port.
Maybe even tune it a bit higher then 30, like 32-34 you will be louder.
But if you play a lot of low low stuff, then keep the 30hz tuning.
  • 2 months later...
aiite thnx man i ended up doing the aero port 4" right now box is tuned at 26hz. subs unbroken in fs was 26hz. THIS IS LOUD AND DESTROYS THE LOWS
-BriAn
Recoil RED 1000.1
Kinetik hc600
5 Farad Capacitor
I'M GLAD
  • Who's Online   0 Members, 0 Anonymous, 552 Guests (See full list)
