how this box seem?
I'm going to be running two 15" SSD Fi's @ 800RMS each (maybe a little less probably going to run a single SAE-1200 @ 16v to get the full 1700RMS sundown claims they can get.)
5.4cuft
6 inch port length
5 inch wide port
tuned @ 33.1hz (33hz)
is this big enough? I measured my trunk in my car and it should fit perfect, and another question... build the box so the subs fire to the back with the port? or fire into the cab with port or fire against the trunk top with vent aimed towards rear?
dunno heard the SAE-1200 will do 1700RMS @ 16v? maybe it was lower?
Pretty sure the 1200D is not supposed to be ran above 15 volts...If you want to run over than you may want to look into the SAZ amps.
If you have good electrical I'm sure the 1200D will give you 1500 watts at normal voltage.
2002 Pontiac Bonneville SSEi
Pioneer DEH-P6000UB
Alpine SPX-17REF 6.5" components (active)
Sundown SAX-50.4
Sundown z15 (3 cubes @ 35 hz)
Sundown SAX-1200D
2006 Buick Rainier CXL AWD V8
Stock Bose system
12" Alpine Type E in aeroported box
Profile AP1000M
  • Who's Online   0 Members, 0 Anonymous, 436 Guests (See full list)
