Thenumber1z Posted February 15, 2010 Report Posted February 15, 2010 I got a Kicker 650.4 and it has the 4 rca inputs on it ie: amp 1, and amp 2. But the problem is my radio only has front outputs and subwoofer. Can I run the front out put on the radio to the inputs on the amp and just split them so I get all 4? Will it sound messed up? Also what brand of rca's should I use? Quote 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
3ddi31002 Posted February 15, 2010 Report Posted February 15, 2010 I got a Kicker 650.4 and it has the 4 rca inputs on it ie: amp 1, and amp 2. But the problem is my radio only has front outputs and subwoofer. Can I run the front out put on the radio to the inputs on the amp and just split them so I get all 4? Will it sound messed up? Also what brand of rca's should I use? yes you can do that all that will affect is the fading part of the system like front left or rear right kinda stuff Quote
3ddi31002 Posted February 15, 2010 Report Posted February 15, 2010 knuKonceptz.com RCA's FTW! very good choice i picked some up last week sounds alot better that scooch or whatever you spell it that you buy at walmart ha Quote
Thenumber1z Posted February 15, 2010 Author Report Posted February 15, 2010 Well I was thinking about ordering my rca's from knuKonceptz because right now both amp's (mids and highs amp and sub amp) are running on cheap rca's from walmart. So I will notice a difference by changing them? Also which ones should I order. What model of rca's (needing to be some what affordable. Quote 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
mbdblue Posted February 15, 2010 Report Posted February 15, 2010 Well I was thinking about ordering my rca's from knuKonceptz because right now both amp's (mids and highs amp and sub amp) are running on cheap rca's from walmart. So I will notice a difference by changing them? Also which ones should I order. What model of rca's (needing to be some what affordable. you might, its hard to tell if you'll notice a diffference but it might clear up your signal...oh and get the klarity cables man vvv http://www.knukonceptz.com/productDetail.cfm?prodID=KLA-5M Quote AA-Atomic-Clif Designs-DC-Diamond-Digital Designs-Directed-Eclipse-Fi-Hertz-Hifonics-Kenwood-Memphis-Phoenix Gold-Pioneer-PPI-PSi-Stinger-Sundown-TC Sounds-Viper-Zapco
Mr. Ben Posted February 15, 2010 Report Posted February 15, 2010 you might, its hard to tell if you'll notice a diffference but it might clear up your signal...oh and get the klarity cables man vvvhttp://www.knukonceptz.com/productDetail.cfm?prodID=KLA-5M you should just be able to switch the amp into 2 rca mode put the rca's in the front inputs and all 4 will work Quote BIG PYMPIN IS BIG PYMPIN IS BIG PYMPIN
Thenumber1z Posted February 16, 2010 Author Report Posted February 16, 2010 I don't think you can do that on the Kicker 650.4! Or if you can how do I do it? Quote 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
Guest Posted February 16, 2010 Report Posted February 16, 2010 http://www.knukonceptz.com/productDetail.cfm?prodID=KRY-1F2M 2 of those should work fine. itll let you keep that subwoofer preout free Quote
Thenumber1z Posted February 16, 2010 Author Report Posted February 16, 2010 Yeah, I already have 2 of them that are gold. I just wanted to make sure they were not gonna make it sound like S*** you know. Thanks though, I'm ordering the rca's from knukonceptz friday so I can replace the walmart set I have now. Quote 1991 Nissan 300zx JVC KD-HDR50 (2)Kicker L7 10's Custom enclosure(Entire hatch) Hifonics 1606D (Subs) Kicker 650.4 (Mids & Highs) Hifonics ZXi 5.2C (Front) Kicker 07DS600 (Rear)
