Dead Amp... advice?
KillaCam
My amp stopped working so I took it in to get tested and its "dead". I took it apart and nothing seems wrong, nothings burnt or anything, nothing smells funny. Id like to fix it myself but I dont know whats wrong with it or how to figure out the problem. I'm guessing that the power supply is bad but idk for sure. I think it blew because I had it wired @ 2ohms and it wasnt very stable... so any suggestions? thanks
btw its a Kenwood Kac-8104d
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
I thought the amp is 2 ohm stable..
Details:
» mono subwoofer amplifier
» 300 watts RMS x 1 at 4 ohms (500 watts x 1 at 2 ohms)
» CEA-2006 compliant
» variable low-pass filter (50-200 Hz at 24 dB per octave)
» bass boost (0-18 dB at 40 Hz )
» subsonic filter (15/25 Hz, 18 dB/octave )
» Class D design
» speaker-level inputs with signal sensing turn-on
» preamp-level inputs and outputs
» fuse rating: 40A x 1
» 8-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 11-1/16"W x 2-3/8"H x 9-7/8"D
Amp costing $109, I personally think it's worth a fix. I would just buy a new one imo...
http://www.amazon.com/Kenwood-KAC-8104D-10...data/B0012Z1M18
My Build Log- T E A M S U N D O W N A U D I O -
2013 DbDrag WF SS1-2 - 5th Place 154.6db
2013 MECA Mod3 CA State Final Champ 153.4db
Powered by: Sundown Audio
  • Who's Online   0 Members, 0 Anonymous, 1760 Guests (See full list)
