Got zip ties thanks a bunch i know these pics made it easy for me and i know it will help other folks.
1st Setup(SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 Audioque SDC2.5 15 subs8.7 cubes at 37hz build DONEAudioque 1200d (Audioque 1200d Sold, similar performance to my ap1500)Diamond Audio Hex 6.5 Mids n TweetsCerwin Vega Exl 400 4 channel Bridged(also have MTX 4004 not being used)1 Run of power Knu Fleks 4 Gauge2 Cheap stock Battery setup2nd Setup (SOLD):2007 GMC YukonPioneer Avic F90bt
Audiocontrol Epicenter2 15 Kicker cvx (maybe two SA 15 in future)7 cubes net tuned at 34hzAlphasonik Old school 1600rms (ap 1500d sold GREAT Budget amp)JBL 6.5 Power Series Components, Infinity Kappa 6.5 3 ways, and 2 Kicker KS Tweets (LOUD)Cerwin vega exl4001 run knu Fleks OFC 0 gaugeBig 3 done1 Odyssey 1500, 1 optima yellow top d31
glad i could help
and really that vid noob posted helped out alot
R.I.P!
(Nov-29-2009)
92 explorer
current build
While you are working on under the hood wiring, I would personally swap out that circuit breaker with a fuse. I've heard too many bad things about circuit breakers.
Definitely that was my old school brother he used to have the old school mid 90's lanzar fifteens very loud but he left the game a long time ago. Im thinking inline fuse holder with a 200 amp fuse since my two amps wont be pulling more than 160 amps and my 0 gauge cant withstand over 350 amps.
yeah they like to start fires from what i've seen
R.I.P!
(Nov-29-2009)
92 explorer
current build
He swears by them but anyhow after i put my inline fuse holder the power wire will go to back seat where i have my amps and it will go to a fused distribution block that also shows my voltage and then i distribute 4 gauge wire to both my bass and highs amp.
this is what happened to my buddys blazor cause his fuse didnt work
R.I.P!
(Nov-29-2009)
92 explorer
current build
correct me if im wrong but that's a 2 door
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
Wow.... Now im going to have to read up if im using the right fuses i thought my 0 gauge can handle 350 amps and dont fuses just protect the wire besides the fuses on the amps that protect the amp. If both my amps are a total of 160 amps is using a 200 amp fuse for my wire ok or should i go lower or higher.
sí senor
and yeah a 200 amp fuse will be enough for your amps
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1144 Guests (See full list)
