AVH-P3100DVD Rearview Camera
getonerd
Well i bought this now once the weather gets nice i goin to hook it up
now pioneer wants me to wire up the violet/white wire to the back lamp so can i hook the wire up to my remote wire or run it to my fuse so i can see who behind my at any time
1996 Chevy Tahoe
AKA My SQ Hoe
Pioneer AVH-X2800BS
Precision Power PC.18DS
MB Quart NA540.6
Skar Audio RP-2000.1D
55-3210 -  8 Inch MCM AUDIO SELECT
Rockville RXM64
Tymphany BC25SC06-04
Kenwood KFC-1795PS
i guess you can try it, it will think that you have it in reverse at all times lol but if it work it works only one way to find out. in the pics theres nothing showing another wire other than the RCA's
all you should have to do is wire up a positive wire and a negative wire and run your video RCA once you switch to your aux input on your HU it should be on. You should only have to wire it into your reverse lights if you only want it to turn on when your backing up. I'd put it on a rocker switch though and mount the rocker on my dash that way its not using power all the time while your car is running. (you would run the positive to a switched + I hope)
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
the camera gets wired to the ignition circuit..it runs at all times as long as the key is on....youll want to put a switch inline with that violet/white wire if you hook it to an ignition source..if not the radio will show the backup camera at all times
1996 S-10 Blazer
Kenwood DNX-6140
(2)Kinetik HC2000
(2)US Amps MD3Dv2
US Amps MD42v2
(4)Hertz HCX-165 (front doors)
(2)Hertz HL-70 (dash)
(2)Hertz HT-25 (dash)
(2)Hertz SX-380D
  • Who's Online   0 Members, 0 Anonymous, 2153 Guests (See full list)
