qjmoten Posted February 19, 2010 Report Posted February 19, 2010 does anybody kno how to parallel wire two 1ohm subs so that you can wire your amp at 1ohm load
micahmye Posted February 19, 2010 Report Posted February 19, 2010 this should work "The Pimp Van" Build "The Pimp Van" Rebuild Youtube Photobucket Feedback For Sale
qjmoten Posted February 19, 2010 Author Report Posted February 19, 2010 this should work so is that safe for the amp and woofers i just never heard of it and sumone recommended it to me
zfrerichs Posted February 19, 2010 Report Posted February 19, 2010 wiring like that is called series parallel you raise each woofer up to 2 ohms then back down to 1 ohm Roseville, CA
micahmye Posted February 19, 2010 Report Posted February 19, 2010 What amp and What woofers are we talking about? "The Pimp Van" Build "The Pimp Van" Rebuild Youtube Photobucket Feedback For Sale
qjmoten Posted February 19, 2010 Author Report Posted February 19, 2010 What amp and What woofers are we talking about? ascendant audio chaos 15s and planet audio bb2400.1
micahmye Posted February 19, 2010 Report Posted February 19, 2010 Yup that amp is 1 ohm stable so you should be fine, If you are running it at anything other than 1ohm then you should get alot more power out of it if you wire this way. "The Pimp Van" Build "The Pimp Van" Rebuild Youtube Photobucket Feedback For Sale
qjmoten Posted February 19, 2010 Author Report Posted February 19, 2010 Yup that amp is 1 ohm stable so you should be fine, If you are running it at anything other than 1ohm then you should get alot more power out of it if you wire this way. oh ok preciate yal...i dont have it hooked up yet i was just seeing the choices i have
