Team Maf Posted February 20, 2010 Report Posted February 20, 2010 Where do yall have your voltage gauge wired into? I heard some would connect to view off their front battery, then some had theirs wired to their battery bank. I personally had mine wired on the battery before my amp. Whats the best place to accurately keep track of voltage? does it matter? Quote ".......Cut spending to only the bare essentials, water and bread...and margaritas...Yaay "-Mr. Marsh 95 camry: JVC Deck 15" Fi Q in a fail prefab box US-Amps Merlin Md2d "Doin' that Work
EricR Posted February 20, 2010 Report Posted February 20, 2010 I personally like to know what my voltage is AT the amp so thats where I have mine wired to Quote i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
CaptainzPlanetz Posted February 20, 2010 Report Posted February 20, 2010 Where do yall have your voltage gauge wired into? I heard some would connect to view off their front battery, then some had theirs wired to their battery bank. I personally had mine wired on the battery before my amp.Whats the best place to accurately keep track of voltage? does it matter? Somewhere close to the amp would be ideal, so a battery in the trunk next to the amp would be fine, also if you can use a DMM to adjust the voltage gauge to get the most accurate reading. Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
Blazerbass Posted February 20, 2010 Report Posted February 20, 2010 im also wondering this since i just bought a volt meter. if you have a second battery you'd think you would connect it there, but hopefully someone lets us know hah Quote http://www.secondskinaudio.com/
Team Maf Posted February 20, 2010 Author Report Posted February 20, 2010 Somewhere close to the amp would be ideal, so a battery in the trunk next to the amp would be fine, also if you can use a DMM to adjust the voltage gauge to get the most accurate reading. Win Quote ".......Cut spending to only the bare essentials, water and bread...and margaritas...Yaay "-Mr. Marsh 95 camry: JVC Deck 15" Fi Q in a fail prefab box US-Amps Merlin Md2d "Doin' that Work
Team Maf Posted February 20, 2010 Author Report Posted February 20, 2010 (edited) im also wondering this since i just bought a volt meter. if you have a second battery you'd think you would connect it there, but hopefully someone lets us know hah Yea cause voltage can differ from front to back over like 12ft+ Just would be a pain to run like another 10ft of wire from your trunk/rear to your dash for the gauge. Edited February 20, 2010 by Team Maf Quote ".......Cut spending to only the bare essentials, water and bread...and margaritas...Yaay "-Mr. Marsh 95 camry: JVC Deck 15" Fi Q in a fail prefab box US-Amps Merlin Md2d "Doin' that Work
Rogers Posted February 20, 2010 Report Posted February 20, 2010 yep either put it on the battery closest to the amp or directly into the amps battery+ terminal... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it?
Team Maf Posted February 20, 2010 Author Report Posted February 20, 2010 yep either put it on the battery closest to the amp or directly into the amps battery+ terminal... Then - to the chasis or the - terminal on amp? Quote ".......Cut spending to only the bare essentials, water and bread...and margaritas...Yaay "-Mr. Marsh 95 camry: JVC Deck 15" Fi Q in a fail prefab box US-Amps Merlin Md2d "Doin' that Work
kl0wn Posted February 20, 2010 Report Posted February 20, 2010 My back battery and front battery always read the same thing at full tilt. So I saved the wire and just wired the volt gauge to the front battery. Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
SGTSKIP Posted February 20, 2010 Report Posted February 20, 2010 ^^^^^^ x 2 Steven Quote Does this smell funny to you? Its your sister
