I want to run 12 DD 510's(4 ohm SVC) woofers on 2 SAZ-2000D's...would it be possible to wire this? like 6 subs on 1 amp?
Six in parallel would be .66 per amp.
R.I.P!
(Nov-29-2009)
92 explorer
current build
yea, it would be
all paralleled is .67ohm to each amp...i guess a sundown could handle that after box rise so long as your electrical is good.
series 3 and parallel, you get 6ohm, parallel 3 and series is 2.67ohm (if you wanted to strap or use amps that like 2ohm)
or run 4 small amps at 1.33 or 1 big amp at 1.33
get to it ;)
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
yea, it would be
get to it ;)
Thanks dude, what would you recommend? as far as how many amps? i like the 1 big amp idea...
With that many subs, I would do 3 amps, 4 subs per amp. The more subs that are on the amp the more imp. rise you will have.
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
  • Who's Online   1 Member, 0 Anonymous, 1190 Guests (See full list)
