not all Chevy rims are the same, nor are all Ford rims the same. Do you know the lug pattern, offset, or if they are FWD or RWD?
what did the rims come off of? and what are they going on to?
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
You need to check to see if the rims are double drilled for two different lug patterns. There are a lot of aftermarket wheels that will fit two different lug patterns that are close to each other, they do this to cut down on cost/overhead. You can take one by a wheel dealer and have them check the lug patterns they will fit and let you know if it will work on your application.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
those two "should" both be the same bolt pattern - 6x5.5" but better to be safe than sorry... DiscountedWheelWarehouse.com - they have a Lug Pattern / Offset Reference.
Man I'm glad I didn't lock this I get to witness two retards holding hands telling each other that it'll be ok because they are awesome.
FAIL! That should've been a link, sorry! Just copy & paste into your browser!
Edited by UKnoitsMe
  • Who's Online   0 Members, 0 Anonymous, 2702 Guests (See full list)
