kanes_disciple Posted February 24, 2010 Report Posted February 24, 2010 I have a fosgate 1000BD and a Diamond audio 500.4 and I was told 150 amp fuses would be fine. I also have a 250 amp fuse and a 300 amp fuse. I wil be running 0 gauge with two fuses in the wire! Thanks! Kenwood Excelon KDX-693 Head Unit Kinetik HC600 Powerbass 6.75's in front doors Powerbass 6.75's in rear deck Powerbass 1000.1D Powerbass 400.4 2 SA-12 inch Sundown Audio Subs 0 gauge Power Wire and Big 3 Custom Amp Rack Code Alarm with remote start Stinger Digital Volt Meter My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/ My youtube channel http://www.youtube.com/user/kanesdisciple
Reallunacy Posted February 24, 2010 Report Posted February 24, 2010 I have a fosgate 1000BD and a Diamond audio 500.4 and I was told 150 amp fuses would be fine. I also have a 250 amp fuse and a 300 amp fuse. I wil be running 0 gauge with two fuses in the wire! Thanks! 250-300 in the wire, and whatever size the amps say in the amps.
David711 Posted February 24, 2010 Report Posted February 24, 2010 I'd use the 250 "WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
kl0wn Posted February 24, 2010 Report Posted February 24, 2010 I'd use the 250 x2. But a 300A will work fine. 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
kanes_disciple Posted February 24, 2010 Author Report Posted February 24, 2010 Will the 150's be too small? Kenwood Excelon KDX-693 Head Unit Kinetik HC600 Powerbass 6.75's in front doors Powerbass 6.75's in rear deck Powerbass 1000.1D Powerbass 400.4 2 SA-12 inch Sundown Audio Subs 0 gauge Power Wire and Big 3 Custom Amp Rack Code Alarm with remote start Stinger Digital Volt Meter My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/ My youtube channel http://www.youtube.com/user/kanesdisciple
01 S-10 Posted February 24, 2010 Report Posted February 24, 2010 Use a 300 up front and a 300 in the back before the rear battery. If the amps need external fusing use whatever they require after the rear battery. TDH FTW !!!
kanes_disciple Posted February 24, 2010 Author Report Posted February 24, 2010 Use a 300 up front and a 300 in the back before the rear battery. If the amps need external fusing use whatever they require after the rear battery. My kit came with a 300 and I had a 250 from a older system, so I will put the 300 up front and the 250 in the back! Kenwood Excelon KDX-693 Head Unit Kinetik HC600 Powerbass 6.75's in front doors Powerbass 6.75's in rear deck Powerbass 1000.1D Powerbass 400.4 2 SA-12 inch Sundown Audio Subs 0 gauge Power Wire and Big 3 Custom Amp Rack Code Alarm with remote start Stinger Digital Volt Meter My build log http://www.stevemeadedesigns.com/board/topic/51869-1996-chevy-blazer-build/ My youtube channel http://www.youtube.com/user/kanesdisciple
