infernobackman Posted June 13, 2007 Report Posted June 13, 2007 so i have one run of 0gague to the back from the front, i have a fuse 12" from the front battery.... do i need to fuse that run of 0gague 12" from the battery's in the back also??? its kind of been explained in some of these threads... but not exactly. well, not enough for me to understand thanks
XtremeSPL-SCAMMER Posted June 13, 2007 Report Posted June 13, 2007 no.. i would not think so.. if you pull enough power it should trip the first fuse.. if you run 0 gauge from the front to the back to another battery located in the back, i would use a fuse right tehre in the back to where it goes to your amps.. other than that, 1 fuse and you are fine.. cause your amps have fuses on them as well.. IMO... it is your vehicle... do as you please... IM A LOW LIFE SCAMMER SO I WAS BANT....TEH HAMMA is NOT my friend
Dale Posted June 13, 2007 Report Posted June 13, 2007 if you have 2 batteries, it is always wise to put 2 fuses between them....one fuse within 12-18" of each battery. Like this: /Battery\=====fuse=========================================fuse====/Battery\
infernobackman Posted June 13, 2007 Author Report Posted June 13, 2007 thats what i was thinking i should do, but is that how its done? or is it just a waste? its the one battery up front, and the 0 gague to the back and then 3 batterys, then my amp fuse in the back, or no fuse
ChevyBoy Posted June 13, 2007 Report Posted June 13, 2007 fuse in the back. is that wire gets shorted out before the read batteries, but after the front fuse, then what? it blows your batteries out back and thats not a nice mess.
