Rob562 Posted March 3, 2010 Report Posted March 3, 2010 Please help... I was told by a shop that i should use a battery isolater. i want to run 2 runs of 0 gauge + and -. should an isolater be used or not and if so how should it be wired. system consits of 2 sundown 2000d,2 orion hcca 15.2 one 300 amp alt kinetik 2000 under hood and 2 kinetik 2400 in the bed. also what size fuses should i use.any help or a diagram would really be appreciated. want to get this truck finished. i have posted before but it was regarding how many runs of 0 gauge. i was checking out the build that steve did on chickens ext since i have an avalanche and was wondering why the circuit breaker?
bobonit Posted March 3, 2010 Report Posted March 3, 2010 Please help... I was told by a shop that i should use a battery isolater. i want to run 2 runs of 0 gauge + and -. should an isolater be used or not and if so how should it be wired. system consits of 2 sundown 2000d,2 orion hcca 15.2 one 300 amp alt kinetik 2000 under hood and 2 kinetik 2400 in the bed. also what size fuses should i use.any help or a diagram would really be appreciated. want to get this truck finished. i have posted before but it was regarding how many runs of 0 gauge. i was checking out the build that steve did on chickens ext since i have an avalanche and was wondering why the circuit breaker? The main purpose of an isolater is to let you drain your rear batteries but leave your starting battery untouched. But this only applies while your vehicle is off. If you are not worried about that then don't bother with the isolater. It would give you a voltage drop anyway. 97 Maxima SE Bunch of shit going in, check out the build Build Log
BeatBox Posted March 3, 2010 Report Posted March 3, 2010 dont waiste your money on it! just my .02, i almost got ripped off the shop wanted to charge me $100 for it installed when it takes only a few minutes to do and you can buy one for less than $30
OLDSKOOL78302 Posted March 3, 2010 Report Posted March 3, 2010 don't waste your time and money.just wire them together.jmo HEAD UNIT JENSEN VM9312 4 12" KICKER COMPS 4 PUNCH 150 AMPS "0NE ON EACH SUB" 2 ALPINE 3522 ON MIDS AND HIGHS MLA MOD BIG 3 OPTIMA D31T BATTERY UP FRONT, ANOTHER IN BACK 2 KINETIK BATTERIES IN BACK ALSO"ONE 800,ONE 1200" DUAL ALTERNATORS "ONE 200 AMP" OTHER MECHMAN 270 LARGE CASE
