what do you guys think of this set up?
do you guys think of this set up will it be good. 2 12" re audio sxx with the US amp xt 4000de v3 (1500 watt rms) i was planning on going with this set up and later on when i save some more money up get another amp and use one for each sub but for now i would use this one amp for both subs.
should i get the subs 2 ohm or 4 ohm. any other suggestions on amps around same quality as the US amp? no AQ.
subs:http://cgi.ebay.com/PAIR-RE-AUDIO-SXX12D4-SXX-12-4000w-SUBWOOFERS-SXX12-D4-/300342122642
amp: http://cgi.ebay.com/ebaymotors/NEW-US-AMPS-XT4000DE-V3-4000-WATT-MONO-CAR-AMPLIFIER_W0QQitemZ350315664719QQcmdZViewItemQQimsxZ20100212?IMSfp=TL100212129013r25319
maybe sundown. if you are staying with 1 amp and it's 1 ohm stable then get dual 4 ohm subs.
'00 Honda Civic Si IASCA stock trunk/pickup 1 World Record 4/20 150.6/150.7dB
Team DC Team XS Power
Team ISB
Steve's Body Shop
http://www.dcsoundlab.com/
what if later on i want to get one more US amp for each sub what should i do??
If you're staying with the 1 amp, just like mhart stated, get Dual 4 ohm, also you can get Dual 1 ohm (That is if those subs even come in dual 1 ohm, I know anything about RE sub's).
If you are going to get another amp later on, 1 for each sub, make the subs dual 2 ohm. But if you make them Dual 2's, and only have 1 amp, you'll either be running the amp at .5 ohm load, or 2 ohm load.
That is if the amp you get is 1 ohm stable..
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
i think it is 1 ohm stable. or should i just go with one amp for both subs would that be a good set up.
does this help?
1,500w x 1 RMS @ 1 ohms
800w x 1 RMS @ 2 ohms
500w x 1 RMS @ 4 ohms
subs are 1000 rms a piece
ok should i just go with one US amp MD3D 2000 watt rms $369. or save a little more money to get two 1500 watt rms xt4000 v3 $598 one for each sub i'll be given them 1500 watt a piece or go with the md3d which they will be getting 1000 watts a piece. what do you think.???
  • Who's Online   0 Members, 0 Anonymous, 1020 Guests (See full list)
