XS Power
I just ordered a d2700 to add as a secondary battery to my system. my front batt. is a cheapo super start batt and i want to know if i can use both of them without using a battery isolator and not have the shitty batt. drain the good batt. any help is greatly appreciated. thanks
(2001 Dodge Durango R/T)
1- XS Power D2700
1-Alpine CDE-HD149BT (Head Unit)
1 pr.- Focal Polyglass 165v30 (Front Stage)
1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill)
1-Kenwood Excelon XR-1S (Sub Amp)
1-Kenwood Excelon XR-4S (Mids-N-Highs Amp)
2- JL 10 W3v3-4 (Subs)
-2.3 Cubes tuned to 32 hz
1-1/0 ga. & Big III in 1/0
140 @45 hz db drag legal
(2008 Toyota Highlander Limited ---build in the works)
1- Kenwood DDX470 (Head Unit)
1 pr.- JL C3-650 (Front Stage)
1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead)
1- JL XD-400/4 (Mids-N-Highs Amp)
1- JL XD-600/1 (Sub Amp)
1- XS Power D3400
1- JL 10w3v3-2 (Sub)
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
1- self-built Fiberglass sub enclosure
if the d2700 will fit up front, swap out the junker
1998 Nissan 200sx
NOW:
Dex-p98r head
Planet Audio 300.4 mids and highs
Planet Audio/Pioneer tweeters/crossovers
Skar SK1500.1
3 SKAR Vvx15 dual 4 wired at .63
x2 your system only needs one good battery
R.I.P!
(Nov-29-2009)
92 explorer
current build
x3 ditch the other one
i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work?
thanks guys. appreciate the help.
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
I knew it was a great battery but i just wanted to utilize all the equipment i had. thats why i was asking. thanks
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
  • Who's Online   1 Member, 1 Anonymous (See full list)
