XS Power
I just ordered a d2700 to add as a secondary battery to my system. my front batt. is a cheapo super start batt and i want to know if i can use both of them without using a battery isolator and not have the shitty batt. drain the good batt. any help is greatly appreciated. thanks
(2001 Dodge Durango R/T)
1- XS Power D2700
1-Alpine CDE-HD149BT (Head Unit)
1 pr.- Focal Polyglass 165v30 (Front Stage)
1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill)
1-Kenwood Excelon XR-1S (Sub Amp)
1-Kenwood Excelon XR-4S (Mids-N-Highs Amp)
2- JL 10 W3v3-4 (Subs)
-2.3 Cubes tuned to 32 hz
1-1/0 ga. & Big III in 1/0
140 @45 hz db drag legal
(2008 Toyota Highlander Limited ---build in the works)
1- Kenwood DDX470 (Head Unit)
1 pr.- JL C3-650 (Front Stage)
1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead)
1- JL XD-400/4 (Mids-N-Highs Amp)
1- JL XD-600/1 (Sub Amp)
1- XS Power D3400
1- JL 10w3v3-2 (Sub)
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
1- self-built Fiberglass sub enclosure
if the d2700 will fit up front, swap out the junker
x2 your system only needs one good battery
R.I.P!
(Nov-29-2009)
92 explorer
current build
thanks guys. appreciate the help.
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
I knew it was a great battery but i just wanted to utilize all the equipment i had. thats why i was asking. thanks
1- XS Power D2700
1- XS Power D3400
1- JL 2 Ga. Amp Kit
1- BIG 3 in 1/0
  • Who's Online   1 Member, 0 Anonymous, 1429 Guests (See full list)
