jl10w3s Posted March 9, 2010 Report Share Posted March 9, 2010 I just ordered a d2700 to add as a secondary battery to my system. my front batt. is a cheapo super start batt and i want to know if i can use both of them without using a battery isolator and not have the shitty batt. drain the good batt. any help is greatly appreciated. thanks Quote (2001 Dodge Durango R/T) 1- XS Power D2700 1-Alpine CDE-HD149BT (Head Unit) 1 pr.- Focal Polyglass 165v30 (Front Stage) 1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill) 1-Kenwood Excelon XR-1S (Sub Amp) 1-Kenwood Excelon XR-4S (Mids-N-Highs Amp) 2- JL 10 W3v3-4 (Subs) -2.3 Cubes tuned to 32 hz 1-1/0 ga. & Big III in 1/0 140 @45 hz db drag legal (2008 Toyota Highlander Limited ---build in the works) 1- Kenwood DDX470 (Head Unit) 1 pr.- JL C3-650 (Front Stage) 1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead) 1- JL XD-400/4 (Mids-N-Highs Amp) 1- JL XD-600/1 (Sub Amp) 1- XS Power D3400 1- JL 10w3v3-2 (Sub) 1- JL 2 Ga. Amp Kit 1- BIG 3 in 1/0 1- self-built Fiberglass sub enclosure Link to comment Share on other sites More sharing options...
c_stud Posted March 9, 2010 Report Share Posted March 9, 2010 if the d2700 will fit up front, swap out the junker Quote 1998 Nissan 200sx NOW: Dex-p98r head Planet Audio 300.4 mids and highs Planet Audio/Pioneer tweeters/crossovers Skar SK1500.1 3 SKAR Vvx15 dual 4 wired at .63 Link to comment Share on other sites More sharing options...
uhoh_45 Posted March 9, 2010 Report Share Posted March 9, 2010 if the d2700 will fit up front, swap out the junker x2 your system only needs one good battery Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log Link to comment Share on other sites More sharing options...
EricR Posted March 9, 2010 Report Share Posted March 9, 2010 x3 ditch the other one Quote i was thinking leave the 12 sitting in the box in the hole and duck tape from the bottom of the sub to the bottom of the baffle so the sub doesnt free air. would that work? Link to comment Share on other sites More sharing options...
jl10w3s Posted March 9, 2010 Author Report Share Posted March 9, 2010 thanks guys. appreciate the help. Quote (2001 Dodge Durango R/T) 1- XS Power D2700 1-Alpine CDE-HD149BT (Head Unit) 1 pr.- Focal Polyglass 165v30 (Front Stage) 1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill) 1-Kenwood Excelon XR-1S (Sub Amp) 1-Kenwood Excelon XR-4S (Mids-N-Highs Amp) 2- JL 10 W3v3-4 (Subs) -2.3 Cubes tuned to 32 hz 1-1/0 ga. & Big III in 1/0 140 @45 hz db drag legal (2008 Toyota Highlander Limited ---build in the works) 1- Kenwood DDX470 (Head Unit) 1 pr.- JL C3-650 (Front Stage) 1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead) 1- JL XD-400/4 (Mids-N-Highs Amp) 1- JL XD-600/1 (Sub Amp) 1- XS Power D3400 1- JL 10w3v3-2 (Sub) 1- JL 2 Ga. Amp Kit 1- BIG 3 in 1/0 1- self-built Fiberglass sub enclosure Link to comment Share on other sites More sharing options...
Nathan @ XSpower Posted March 9, 2010 Report Share Posted March 9, 2010 The 2700 will give you about 3500watts of power as your starting battery. Quote Link to comment Share on other sites More sharing options...
jl10w3s Posted March 9, 2010 Author Report Share Posted March 9, 2010 I knew it was a great battery but i just wanted to utilize all the equipment i had. thats why i was asking. thanks Quote (2001 Dodge Durango R/T) 1- XS Power D2700 1-Alpine CDE-HD149BT (Head Unit) 1 pr.- Focal Polyglass 165v30 (Front Stage) 1 pr.- Hybrid Audio Technologies C61-2 (Rear Fill) 1-Kenwood Excelon XR-1S (Sub Amp) 1-Kenwood Excelon XR-4S (Mids-N-Highs Amp) 2- JL 10 W3v3-4 (Subs) -2.3 Cubes tuned to 32 hz 1-1/0 ga. & Big III in 1/0 140 @45 hz db drag legal (2008 Toyota Highlander Limited ---build in the works) 1- Kenwood DDX470 (Head Unit) 1 pr.- JL C3-650 (Front Stage) 1 pr.- JL C2-525 (Rear Fill, may upgrade to 6.5" C2 or C3 instead) 1- JL XD-400/4 (Mids-N-Highs Amp) 1- JL XD-600/1 (Sub Amp) 1- XS Power D3400 1- JL 10w3v3-2 (Sub) 1- JL 2 Ga. Amp Kit 1- BIG 3 in 1/0 1- self-built Fiberglass sub enclosure Link to comment Share on other sites More sharing options...
