The alt doesn't say it anywhere on it. The truck is a 1997 Chevy Cheyenne 4.3L V6. if you need more info let me know. I have tried Google but haven't found anything.
1997 Chevy Cheyenne Single Cab
Pioneer DEH-3200UB
Two sets of Orion 6.5" Components In Each Door
AudioQue HDC3 15"
^^^ Its all For Sale!!!!! http://www.stevemeadedesigns.com/board/topic/99546-lots-to-sale-good-prices/ ^^^ AQ2200D
Wow, such a flexy beast(see what i did there lol)
Guest Scylloga
I wen tto Oreilys website and punched in your info.
It shows three different ones but a 105 amp is the most common.
SO I would think prolly around 105amps.
Almost all GMs for the past 20 years have had 105 amp alts
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
about 100-110 amps depenind on the company
or on the oem is about 100
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
should be some codes in your glovebox that will tell you
01 Tahoe
Big 3
20 ft.1/0 streetwire under hood
4 Batteries
Stock Battery and
1800 Kinetic Batt under hood
2 Sprinter S12V500F Battery,165 AH
Kicker 1/0 going from front to back
Sirius sportster
Alpine 9886
Kicker 650.4zx mids and highs
Q-Logic kick panels w/Kicker6 1/2 comps.
XXX re comp 6.5 in front doors
Alpine6.5 coax in rear doors
2 Audioque 2200d strapped
2 Audioque 18 HDC3
5% all the way around
2 layers raamat on roof
doors covered in raamat
any gm 4.3 is a cs 130 style case so about 40 amps at idle 105 at around 2000 rpm, like everyone else said. but, good trick to know. the 6.0 is 140 at idle and 200 at 2000 rpm with the same bolt locations and wire harness :)
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Check your glove box for these codes. I'm only listing the GM RPO's for alternators 100 amp or higher here.
8A7, KG8 - 130 amp
8A3, KW2 - 124 amp
8A5, 8C0, K98, KG9 - 140 amp
8C6, KG3 - 145 amp
8C7, KG4, KG5 - 150 amp
8W5, 8X5, K61, K62, K65 - 105 amp
8Z3, 8Z4, K60 - 100 amp
K09 - 120 amp
K63 - 110 amp
KG7 - 125 amp
KW1 - 160 amp
KW3 - 135 amp
KW7 - 170 amp
KW9 - 190 amp
KYU - 200 amp (
01 Tahoe
Big 3
4 Batteries
Stock Battery and
Sirius sportster
Alpine 9886
2 Audioque 18 HDC3
  • Who's Online   0 Members, 0 Anonymous, 4525 Guests (See full list)
