Is it true that mounting your amps directly onto your box is not good for the amps? I have both my amps mounted in back of my box. I did this to clear a little space in my trunk. Also I like that look of not being able to see what is going on in the trunk when you open it, but if this is going to cause damage to my amps let me know I'll re mount.
HU: Kenwood KDC-MP745U.
Sub: AQ HDC 15
Amp: Hifonics BXi 1610D for sub, ZXi 6410 for mids highs
Speakers: 6.5 premium MB Quarts components,6.5 MB Quart premium coaxial back doors
Wiring: KLMX Kable 1/0g for Big 3.Double up 4g from battery to trunk...for now.
Big 3: YUP!
Battery: Shuriken SK-BT35 to the trunk.
Randoms: Flush mounted Stinger blue digital voltmeter. Flush mounted Memphis 7band EQ- 16-EQ50. phoenix gold 2 channel line driver.
iv never had a problem with it. it is a good idea if u are gonna do it to put rubber bushings between the amp and box tho
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
Rubber brushes??? Those are just fat rubber "o rings correct" this is just to reduce the vibration right?
Sub: AQ HDC 15
Big 3: YUP!
yes sir that is correct
pioneer DEH-P8400bh
XS Power D1200
Shuriken BT-100
audioque 120.4
2 audioque 2200d
big 3
479-418-3056
Either way rubber or not, mounting it there is not going to cause it any harm to my amps? I spent my break looking at some of the other post and I read a few places were people blame the vibration from the amp being mounted on the box for causing the amp to fail or shut down. Want to make sure I'm safe.
Sub: AQ HDC 15
Big 3: YUP!
your fine unless you're pushing 5-30kW but I'd put the rubber bushINGS between your amp and the box if for nothing else it'll help keep it cooler
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
30,000 watts, LOL I haven't Steve'd out yet! I'm running a baby 1900 watts all together. I'll do the safe thing and rubber up... thanks for the input.
Sub: AQ HDC 15
Big 3: YUP!
Stack 2 or 3 of these between the amp and box and you should be fine
http://www.lowes.com/pd_139364-37672-881259_0_?productId=3013202&Ntt=rubber%20washer&Ntk=i_products&pl=1&currentURL=/pl__0__s?newSearch=true$Ntt=rubber%20washer$y=0$x=0
Its always good to use those rubbers ;)
under construction
I hate People with crappy primered cars rolling on hubcaps that are louder then me.
u hate c-fizzy?
