Been reading and reading, playing with box calculators, anything that I can think of. 1 think I just cant seem to get is, does the air volume in the port belong to the port or the enclosure?????? Been very frustrating that I can't figure this out, is there a resource that some one could point me to to understand this better??? Been trying to get a box designed for my 15's but this has me seeing nothing but ID-10-T errors :blink: !!!!!!!
<>< Collosians 2:13-14, Philippians 4:13, 1 John 4:7-10
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
So, if I were to build a box to house both woofers and have a common port. Do I just double the enclosure cubes and port volume? Sub data sheet and recommended enclosures, Looking at this and according to my assumption, the box would be 8ft3 with a port volume of right around .5ft3 (more accurately 855IN3????
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
Thats correct. You want to account for the total displacement of the port so you need to have the port in hand and measure the actual outside dia of the port. It may be 6.25in or so. You also dont want to subtract the total length of the port. The portion passing thru the enclosure wall, 3/4 in for a single wall and 1.5" for a double wall shouldnt be added to the length. Just the portion that is inside the enclosure. Account for the sub displacement and any bracing you will be adding.
In the data sheet, it says the enclosure volume includes driver and port displacement. does that me that after all displacements the net air space should be 4ft3?
If thats the case just build the box 8 cubic feet and add the ports and subs. The displacements have been allowed for already. If you add bracing you will need to account for that. Your net volume will be 3.7 something per sub. That will be just fine for those subs.
Thanks for your help bro!!!!
2 - JBL W15Gti
2 - JBL BP1200.1
Knu 1/0 Wiring
Kenwood KIV-BT901
Kenwood/Garmin Nav.
  • Who's Online   0 Members, 0 Anonymous, 965 Guests (See full list)
