1990 Lincoln Town Car HU install
Alright so im trying to install this cheap pioneer deck into this 90' town car i just bought.
I've searched all through the interwebs trying to find the wiring diagram, but they dont include the speaker connections.
this is my first install im trying to do by myself so i'd appriciate any help.
I've got it too light up, so i've found the switch 12v connection and the ground, didnt find the constant 12v, there was not a white/purple wire on the factory harness like this diagram (http://www.the12volt.com/installbay/stereodetail/1326.html) said there would, so just jumped the switched 12 to the constant and turned on the HU like that,
now about the speaker outputs, i guess im going to have to butcher this other 'harness' cause im guessing the speaker connects are in there since its a 8 connection cable, so take a look
Got it to light up.
IMG00569.jpg?t=1268262227
This is the harness where i got the power and ground
IMG00572.jpg?t=1268261955
And im guessing im going to have to cut up this one to find out which connections belong to which speakers, or is there any other way to find out? I've heard something like getting a 9v battery and just plugging them into the connections or whatever, just never done it myself
IMG00571.jpg?t=1268262101
im going to either solder and tape or use those twist connecters for all the wires, im not going to just leave them all exposed like that, i just did it like this real fast to see if i could find the power and ground for it which i did
also i will eventually run the RCAs back when i get my power cable for my small 2channel amp for my rear 6x9s
again thanks for any advice
9515g
xa-3000s
the black with green stripe is your constant 12v
the other plug is the low level to the factory amp, in the trunk pass side on the back of the seat
just go to walmart and buy a harness for amplified 90-94 ford.
local shop
no kit needed.
just put the cage in the hole, crimp it down and dun son
  • Who's Online   0 Members, 0 Anonymous, 1171 Guests (See full list)
