i have 2 brand new prestige 12's in a box that i built just for the 12's its 1.5 cf per sub tuned to 33 hz , box weighs about 30 lbs and then subs, subs are brand new used for 3 days and not pushed hard yet. they are dual 2 ohm voice coils with a huge surround rms is 350 and 700 max , on my funkin audio mf 400 im running the subs at 2ohms on the amp and given them 300 watts each and they get loud and low
box is 30wx15dx14.5t outside measurements
but since i recently picked up some diamond audio 12's that are more power capable of handleing my new pa 3000D i dont need the 2 prestige 12's
paid 150 for both subs and box is about 125 if you had it built by someone else
asking $150 plus 1/2 shipping (aprox $15.00 inside usa)
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
hey got a question is that port like a t-port or does it just have one port wall
"MY RIDE"
1987 Chevy Cavalier Z24 2.8L V6 -- CB Radio with PA speaker
Head Unit: 7 inch Jensen Flip-out -- Speakers: 4 Visonik 6 1/2s and 4 Visonik 6x9s
Subwoofer: One Audiobahn 18 - Sub Amp: Power Acoustik OV1-2000d 2000 watt monoblock amp --
Battery in back - Kinetic HC600 -- Sub box: Custom built 5 cubic foot tuned to 30 hertz
Coming soon: Bigger Highs Amp, Power inverter
"WhItE bOi AuDiO"
"FEAR THE DUCK"
it is a very small t port , but in other words it goes all the way back and then it has a very small end on both left and right side to make a T
hey do u have problems with air getting into the other enclosure cause i am about to build a enclosure for my tens just like that but i was going to make a 45 thing to put at the end of the back wall in the center of the port if u saw how meade did it for a box with the ports being flared for two 2 12's
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
when i put alot of time into my boxes i put 45's in each corner and route every edege with this box i only routed the edeges with out the 45's since its in the trunk i wouldnt be able to notice a differce with or without them...now if i was going to compete with the set up then i would have done all the bells and whistles with the box but its just a daily pounder
cool just asking imma talking about the port where the two chambers meet do the air just blow out or does some get into the other chamber
"MY RIDE"
"WhItE bOi AuDiO"
"FEAR THE DUCK"
well i never did a smoke test to see where the air blows but if your subs are in proper phase they should both force the air out of the port instead of one sub over powering the other and causeing more air blowing into the others chamber?....honestly i dont know the answer to your question but ive never had a problem with one sub being affected that i could tell from the other sub being played
This topic is now closed to further replies.
