MACnonsence6 Posted March 13, 2010 Report Posted March 13, 2010 my cousin sold me this amp a while ago after he blew the speaker in it http://bass-guitars.musiciansfriend.com/product/Behringer-Ultrabass-BXL3000-300W-1x15-Bass-Combo?sku=481097 i had it running 2 pyle 15" subs for a while just like a power amplifier not as a bass guitar amp it ran those fine for ever but now after its been sitting for about a year or so it wont work i cant fingure it out on the inside it has a green power on light and a red clip light both of those work it will power on and the clip lite lights up when i play my bass threw it at full volume like it should but theres no power to the sub i have hooked up fuses seem to be good what do u guys think. i can get a pick of the board up tomaro if u guys like I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
MACnonsence6 Posted March 13, 2010 Author Report Posted March 13, 2010 new info took the board out looked it threw it seems to be fine no burn marks look brand new hooked everything up plugged it in hooked up a little 5" sub to it and it moved then has a very very very quit buzz going threw it anythoughts as to what could be doing this? still not getting a signal though please help I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
Loudcivic Posted March 13, 2010 Report Posted March 13, 2010 not sure about that this is mostly a car audio forum you might get more help from a forum for guitar amps 2015 silverado crew cab nothing atm but soon...
MACnonsence6 Posted March 13, 2010 Author Report Posted March 13, 2010 well seeing how i am in the home audio section and i have been using this amp to power a sub i think im in the right spot thanks though. also seeing how the same electronics apply i think that i am just in posting here I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
MickyMcD Posted March 14, 2010 Report Posted March 14, 2010 G'day buddy, Behringer instrument amplification has a notorious reputation for this kind of behavior. It is very possible that the amplification stage was only designed to be stable at an eight ohm load, and no lower. You may have possibly blown an output device or more from driving loudspeakers the unit was not designed to drive. Also possible is that by letting it sit for so long, the internals have given up the ghost. Behringer does not use high quality components in their instrument amplification range, and it would not surprise me if the capacitors on board no longer hold charge. For many B-factor (Behringer)products, you can't really trust their reliability. It's like trusting a Firestone tyre tube around your dong to protect you from an infection when you jump in a pool of liquified herpes. Cheers, Mick Work;DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS VeniceMeyer Sound CQ-1's, CQ-2's, PSW-2'sRAMSA Monitor AmplifiersP.Audio MonitorsBSS OMNIDRIVE and SoundwebDBX 231 and Klark Teknik DN360 EQ'sRCF TT22ARCF ART320
Boon Posted March 15, 2010 Report Posted March 15, 2010 It's like trusting a Firestone tyre tube around your dong to protect you from an infection when you jump in a pool of liquified herpes. Cheers, Mick You, sir, are one of the better things I've ever found on the internet. 10.x volts fo' life!
MACnonsence6 Posted March 19, 2010 Author Report Posted March 19, 2010 i do think that one of the caps has given up becouse if i power it on it pops then humz which tells me the cap had charged then discharged? also if i turn it on then unplug the fuze for the speaker it does nothing for a second then pops again wich again leads me to think its a bad cap. is there a way to replace the cap or how would i do more checks to make sure thats what it is. thanks for your reply I picked up an MTX Sw1212 powered subwoofer today. This thing sounds amazing. 130 watts, 12" woofer with a passive 12" woofer tuned to 27 hz. Moving the pictures on the walls and my girl got wet from the bass when i showed her haha. Tonight should be good haha.
