immortal_82 Posted March 17, 2010 Report Posted March 17, 2010 Hi all... Help needed,Did we have any formula about calculate space in the truck or in the car if we put the enclosure then we can feel the flow air going out to make the best hair trick...
davewms9605 Posted March 17, 2010 Report Posted March 17, 2010 Hi all... Help needed,Did we have any formula about calculate space in the truck or in the car if we put the enclosure then we can feel the flow air going out to make the best hair trick... say what? Current Setup: Sony CDX-7401UI 2- 12" Alpine TypeR DVC2ohm Subs Custom ported box 4-American Bass 6.5in SQ-6B Mids 4-Pioneer TS-T15 Tweeters 2-Crunch P1500.1 Mono Amps 2-runs 1/0 GA KnuKonceptz KnuKonceptz RCA's 1-Stinger SPV44 Battery Coming soon: 250 Amp Alt Custom Door Panels Second Skin Sound Deadner All in my 1986 Monte Carlo SS!!!
cqtama Posted March 17, 2010 Report Posted March 17, 2010 Hi all... Help needed,Did we have any formula about calculate space in the truck or in the car if we put the enclosure then we can feel the flow air going out to make the best hair trick... errr. im gunna take a shot at this: Did we have any formula about calculate space in the truck or in the car if we put the enclosure then we can feel the flow air going out to make the best hair trick... = how do i get a good hairtrick... maybe, idk R.I.P '01 blazer you treated my ears well until your transmission blew up. New Project [top secret] 149.0 db on music driver window open; so close I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean.... I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Neo_frog Posted March 17, 2010 Report Posted March 17, 2010 Malaysia. I'm guessing English is not the strongest? There's no equation for the car itself. There are for box tuning though, and a good hair trick requires lots of power and/or cone area (lots of subs). Trunk cars are not easy to make hair tricks, but it can be done with the right setup. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
raytard Posted March 17, 2010 Report Posted March 17, 2010 best hair trick=lotts of power (10kw rms+)+lots of cone(2 18's at minimum)+low tuning(32hz or less)+box in common chamber where window is(not sealed in a trunk, we need airflow, not sound) do that and you'll have a hairtrick. to do better ones, more power/cone/lower tuning. its simple Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
immortal_82 Posted March 17, 2010 Author Report Posted March 17, 2010 best hair trick=lotts of power (10kw rms+)+lots of cone(2 18's at minimum)+low tuning(32hz or less)+box in common chamber where window is(not sealed in a trunk, we need airflow, not sound) do that and you'll have a hairtrick. to do better ones, more power/cone/lower tuning. its simple Thank a lot bro.. I'm really appreciated...
