i was wondering if a bxi 2610 powers perfectly two 15 l7.
maxxsonics says the 2610 will put out 1700 watt rms @ 12 volt.
one 15 l7 in a ported box has 750 watt rms power handling so its even a little overpowering the subs.
any opinions?
Actually what it says is 1700 watts rms @ 2-ohms, not 12 volts. If you put a hifonics amplifier at 12 volts, not only is your voltage low, your amplifer will never make rated power. As long as you are smart about the gains, send the amplifer clean signal at all times, put them in a quality box built to specs, you should be fine.
1997 Chevrolet Cavalier Two 12" DC Audio XL M2'sCrescendo Audio BC5500d
Current Scores: 150+ out the Trunk
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
I think you will be fine the 15" L7's are rated at 1000rms a piece, so you wont be overpowering em by that much.
¿ǝɯɐƃ ǝɥʇ
In that case, just buy them with the right voice-coil configuration to achieve a 1-ohm load and again, be smart with your setting. To the OP: You said 750rms in the first post therefore i assumed 750 and not 1000, if that is the case (1000rms), you wouldn't be giving them full power out of an amplifier that is perfectly capable of doing so putting them at 2-ohms as opposed to 1. :/
i contacted maxxsonics and i was told the bxi 2610 will put out 1700 watt rms @ 1 ohm @ 12 volt.
the manual says ported l7 handles 750 watt rms, sealed 1000 watt rms.
my 15 L7 build
my youtube channel with lots of L7 videos
Just buy D4s and wire them to a 1ohm final load. I've seen them daily take around 1500w without issues as long as the gains are set accordingly and it's in the right enclosure.
Pioneer AVIC-N2
  • Who's Online   1 Member, 0 Anonymous, 1701 Guests (See full list)
