So i ordered a 12" street duty aq sub and it says 600 rms(continuous power).
So ive been looking at mono amps that say 600rms, now, do i look at the power for 4ohms, 2ohms, or 1ohm or what?
If anyone can help thatd be great.
What coil is ur sub?
"in the abundance of water, the fool is thirsty" Bob Marley
I havent got the sub yet, its on it way, i ordered it about a week ago.
this is what aq says about it though:
These subs were designed to hit hard, sound great and last a long time. The 2.5″ DUAL voice coil diameter is big enough to handle the long-term power while light enough in mass to yield high output. The coil is coupled to a strong multi-fiber cone that is reinforced with an epoxy resin dust cap. The EROM, high roll surround is efficient in both excursion and cone area. The suspension follows our philosophy of multiple, high compliance spider layers for tight bass with low fatigue over the long haul. The lead wires are formed into these spider layers which further enhances durability and eliminates lead slap/breakage problems. The frame is cast aluminum with a sandblasted, powder coat finish. The motor parts are all machined with a black epoxy finish to aid in heat transfer. The tight tolerances of the SD2.5 motor provides high energy without excess weight. These subs use the finest parts that can be found, are hand assembled to maintain the tightest tolerances and made especially for you. Everything about the SDC2.5 subs is dedicated to delivering the pounding bass you need. The SDC2.5 series fills the void between the SDC2 series and the HDC3 super woofer. It is the perfect choice for raising the bar in power levels to get that extra bass but still be in the 500-600 watts power range.
It doesnt exactly say what its made of though
then its a 2.5" DVC sub it all depends on how you wire the sub (I wouldn't go any lower then 2 ohm)
1998 Plymouth Voyager (daily)
Jensen VM9213 H.U. (I Know but I havent had any problems.... yet)
5.25" Factory -> Sound Stream SST5.2
6x9 Hifonics ZXi 693 -> Sound Stream SST6.9
Amp: Class D: Crescendo 3KWP (x2)
Class A/B: Crescendo 1000C4
Sub: Almani S-7 10" (x6)
ok, thanks
so i should be looking for amps that say 600rms at 4 or 2 ohms then?
2 OHM what brands are you looking at exactly?
i personally always look for one that can do power at 1 ohm. less strain on electrical and no audible difference in quality
HOWEVER
you do need to know what ohm the coils are. that limits your choices
you cant make a decision until you know that
Edited by IH8PunkRok
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
heres a chart provided by aq, im not sure if this helps at all
Specifications
Model SDC2.512
Woofer Size 12″
Fs 32 Hz
Qts 0.471
Qes 0.533
Qms 4.085
Vas 36.7
Le mH 1.89
Sensitivity 1W/1m 88 dB
Magnet Weight 140 oz
Coil Diameter 2.5″
Useable Throw 2.3″
Continuous Power 600
Music Peak Power 1200
Mounting Depth 6.5″
Circle Cutout 11.1875″
stop quoting stuff from AQ it doesnt help
i cant tell you what to look for until i know what ohm coils you got.
figure that out then come back
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 11877 Guests (See full list)
