Vangel Posted March 19, 2010 Report Share Posted March 19, 2010 So i ordered a 12" street duty aq sub and it says 600 rms(continuous power). So ive been looking at mono amps that say 600rms, now, do i look at the power for 4ohms, 2ohms, or 1ohm or what? If anyone can help thatd be great. Quote Link to comment Share on other sites More sharing options...
Watch the bass Posted March 19, 2010 Report Share Posted March 19, 2010 So i ordered a 12" street duty aq sub and it says 600 rms(continuous power). So ive been looking at mono amps that say 600rms, now, do i look at the power for 4ohms, 2ohms, or 1ohm or what? If anyone can help thatd be great. What coil is ur sub? Quote "in the abundance of water, the fool is thirsty" Bob Marley Link to comment Share on other sites More sharing options...
Vangel Posted March 19, 2010 Author Report Share Posted March 19, 2010 I havent got the sub yet, its on it way, i ordered it about a week ago. this is what aq says about it though: These subs were designed to hit hard, sound great and last a long time. The 2.5″ DUAL voice coil diameter is big enough to handle the long-term power while light enough in mass to yield high output. The coil is coupled to a strong multi-fiber cone that is reinforced with an epoxy resin dust cap. The EROM, high roll surround is efficient in both excursion and cone area. The suspension follows our philosophy of multiple, high compliance spider layers for tight bass with low fatigue over the long haul. The lead wires are formed into these spider layers which further enhances durability and eliminates lead slap/breakage problems. The frame is cast aluminum with a sandblasted, powder coat finish. The motor parts are all machined with a black epoxy finish to aid in heat transfer. The tight tolerances of the SD2.5 motor provides high energy without excess weight. These subs use the finest parts that can be found, are hand assembled to maintain the tightest tolerances and made especially for you. Everything about the SDC2.5 subs is dedicated to delivering the pounding bass you need. The SDC2.5 series fills the void between the SDC2 series and the HDC3 super woofer. It is the perfect choice for raising the bar in power levels to get that extra bass but still be in the 500-600 watts power range. It doesnt exactly say what its made of though Quote Link to comment Share on other sites More sharing options...
blackrosetiger Posted March 19, 2010 Report Share Posted March 19, 2010 then its a 2.5" DVC sub it all depends on how you wire the sub (I wouldn't go any lower then 2 ohm) Quote 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6) Link to comment Share on other sites More sharing options...
Vangel Posted March 19, 2010 Author Report Share Posted March 19, 2010 ok, thanks so i should be looking for amps that say 600rms at 4 or 2 ohms then? Quote Link to comment Share on other sites More sharing options...
blackrosetiger Posted March 19, 2010 Report Share Posted March 19, 2010 ok, thanks so i should be looking for amps that say 600rms at 4 or 2 ohms then? 2 OHM what brands are you looking at exactly? Quote 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6) Link to comment Share on other sites More sharing options...
Vangel Posted March 19, 2010 Author Report Share Posted March 19, 2010 well im not exactly sure, im looking for an amp that is around 250$ shipped, if theres and amp you recomend please let me know. Quote Link to comment Share on other sites More sharing options...
IH8PunkRok Posted March 19, 2010 Report Share Posted March 19, 2010 (edited) i personally always look for one that can do power at 1 ohm. less strain on electrical and no audible difference in quality HOWEVER you do need to know what ohm the coils are. that limits your choices you cant make a decision until you know that Edited March 19, 2010 by IH8PunkRok Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
Vangel Posted March 19, 2010 Author Report Share Posted March 19, 2010 heres a chart provided by aq, im not sure if this helps at all Specifications Model SDC2.512 Woofer Size 12″ Fs 32 Hz Qts 0.471 Qes 0.533 Qms 4.085 Vas 36.7 Le mH 1.89 Sensitivity 1W/1m 88 dB Magnet Weight 140 oz Coil Diameter 2.5″ Useable Throw 2.3″ Continuous Power 600 Music Peak Power 1200 Mounting Depth 6.5″ Circle Cutout 11.1875″ Quote Link to comment Share on other sites More sharing options...
IH8PunkRok Posted March 19, 2010 Report Share Posted March 19, 2010 stop quoting stuff from AQ it doesnt help i cant tell you what to look for until i know what ohm coils you got. figure that out then come back Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build Link to comment Share on other sites More sharing options...
