Ok so out of nowhere I hit my bassknob for two seconds then noticed my center stage and right front went really quiet and staticy. So I stick my hand. Behind my indash and rattle wires and they started working again. As soon as I hit the bass it went out again. Only the front left rca output works rhe others are barely workng and static.
However when I turn my truck off and back on it works until I bump loud just the front right and center stage stop working
I checked the grounds and shook every wire and nothing. I can't get it to cut out that way until I hit the bass full tilt.
Headunit I've had for four years its a panasonic double din touch screen. Even if a shop tests it I'm afraid it won't fudge up unless he has subs. Anywayh I'm so lost and don't know what to do.. any input??
I did ....what wire would only effect those certain outputs.... I think something in the radio is fudged.....
could i use my DMM somehow and check a certain OHM or voltage ?
  • Who's Online   0 Members, 0 Anonymous, 1093 Guests (See full list)
