Hey! I'm in the process of making this vented box for my two 12" subs. I have all the materials and tools needed, but I can not figure out the dimensions needed. I have the specs on the subs: the net volume on a vented box is 2.0 ft3 and I have two so total net volume of 4.0 ft3 is needed in the box. It needs to be tuned to 35 Hz also. It also can't be taller than 15" and wider then 34" to fit perfectly in the trunk (depth isn't a problem). Any help on this one? Thanks.
I got this sketch from another post, but it's only 3.0 ft3 and tuned to 30 Hz, so if you could alter this one that would be fine too.
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Alpine KTP-445 Power Pack
-Polk Audio db6501 (front components)
-Polk Audio db651 (back coaxials)
-2 RE Audio SEX12D4s
-Cadence F1200-1D
- Custom box tuned to 33Hz
- Kinetik HC1400
- 50 ft2 of Audio Technix sound deadner
- Big 3
My photography page
34" 15" 17.5" using 3/4" MDF 15" port length
your depth would be 19" if you use 1" MDF
Edited by Purdy
On 4/20/2010 at 10:06 PM, 'cc_audio' said:
Guys are just like girls, once you've had 18 inches you don't go back.
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
Sub Amp- (2) PPI 5000BD.1
(2) Re SXX 15's 8 cu. ft. box tuned to 32 Hz
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
(2) 1.5" Bose Tweets
(1) JY 80 AH w/ new JY busses
(1) Duracell 750 up front
Apex Alternators 270
A.C. Delco 160 alternato
nothing on how to tune it to 35 Hz tho?
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Cadence F1200-1D
- Kinetik HC1400
- Big 3
My photography page
the port is what tunes it to 35hz
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
and thats 5.2 cF dude i nedd 4.0 cF...
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Cadence F1200-1D
- Kinetik HC1400
- Big 3
My photography page
depth has to be (edit) its actually 16.9" i believe cuz isnt the equation: (HxWxD)/1728=V (in cF) but then i put into that calculator and it says 18.5" fer the depth....
Edited by manofthehour
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Cadence F1200-1D
- Kinetik HC1400
- Big 3
My photography page
use that box calculator i sent you
and you are going by outside dimensions you have to use inside dimensions
Edited by Purdy
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
and you can not get 4 cubes if your depth is limited to 16.9 but you will get close
2004 GMC Yukon XL
Pioneer AVH-X4700BS
13 band EQ
(4) 6.5 Bose Mids
(2) 1" Bose Tweets
ok on the calc u just sent me im using the inside dimensions...
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Cadence F1200-1D
- Kinetik HC1400
- Big 3
My photography page
ok 18.4" is the majic number but i havent taken in account the fact that ill have to brace it (and i dont even know how the heck to do that) BUT did i need to subtract the port walls from the volume itself?
My stuff
'06 Scion xA:
-Alpine iDa-x100
-Cadence F1200-1D
- Kinetik HC1400
- Big 3
My photography page
  • Who's Online   0 Members, 0 Anonymous, 730 Guests (See full list)
