Re-attatchng Spider...
Guest jbinn
Ok so I setup a system for my friend even built him a box, it was my first time and it came out awesome... well anyways to the point he has:
Hifonics DVC 4OHM 12" Atlas (never tried it before but @ 600RMS for $134 I thought why not?!) and we ran it on
Alpine MRP-500.1D @ 2OHM (wire correctly rechecked etc.) it was pounding hard no clipping (set with DMM)and sounded great, hit lows nice for about a week...
the driver stops moving and the driver is just stuck in outward position could push it in... so we let it settle for awhile and just tapped the cone and the driver went back to normal...
There was no rubbing or coil sounds so we take the subwoofer out, the coils are in awesome condition and in there nice, the tinsil leads are perfect everything is fine, i pull up and the whole spider had come off... like the glue wasnt on there good or something, so now I have to re-attatch the spider, will the woofer be fine if I do this? is it really damaged for good? or can some really good adhesive fix it?
nobody can tell me?
google is your friend
/free bump
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
all i can say is, it cant hurt to try.
CA glue is the preferred glue for joint fixes
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Guest jbinn
well it was glue that held it there in the first place , it just seems like htey did a shitty job on the assembly line lmao... I just want to know if i re-attatch the spider if it'll work fine again the thing is brand new
keep one thing in mind, you get the soft parts out of alignment since you cant shim it to reglue it with the dust cap still on it and yer gonna have a nice life in coil rub land...
Daily Driver 1999 Kia Sephia
Kenwood DNX-893s
Audison Bit One Processor
2 Dat 4.125's
Sundown Audio SCV-6k
Hertz hsk-165xl's Mids running active        Focal V30 Series Tweeters running active
Sundown Sa-8 v1's in the doors
2 Sundown Zv5 12's
Lots of Hushmat
Big 3+ and 3 + & 3- runs of Trystar 2/0
2 Dc Power Engineering 320 HP Alts
2017 Comp Vehicle
2006 Toyota 4 Runner
Kenwood Excelon DNX-893s        Audison Bit One HD DSP
4 Sundown Sa 6.5v2 Component Sets
Focal Access 6.5 2 ways
Sundown Audio Sax-50.4        Sundown Audio Sax-100.4
2 Dc Power 370xp
Northstar agm27f
Northstar agm65
2 Northstar asmagm 480's
2 Dual 1 Sundown Nightshade v3 12's
2 Sundown SCV-7500's
All SMD Fuse Holders
Shitload Of Sundown 1/0
120 sq ft Second Skin Damp Pro
No, Its Not A Burp Truck!!!!
2016 Season 3rd place in Xtreme 1 At Finals
2016 Season 6th Place In Kaos 1 At Finals ( Blew The Subs Up In First Round Eliminations)
2 Kansas State Records Set In 2016 In Xtreme 1 And Kaos 1 In Midwest SPL
David said:
audio is a lifestyle, not a hobby
newls1
I cant read a tape to save my life... 1/2's are ok, but other marks confuse me
kingsuv
only men who cant read a tape, take it in the ass
kingsuv
you sir, get a pink hard hat on jobsites
Guest jbinn
Well the subwoofer is like one week old, it wasnt overpowered or clipping the ONLY problem is the spider came lose from the gasket should I send it back or attempt repair? the coil seems to be aligned and in good shape i hear no rubbing just the spider is lose.
Guest jbinn
soo if i put the spider back on the coil wont in in sync and it'll rub? or do you think im ok , I cant send it back to for warranty if i try to reglue the spider...
  • Who's Online   0 Members, 0 Anonymous, 1510 Guests (See full list)
