  • 1 month later...
Ok so I finally got them both installed and up and running. As far as the setting go when you have one amp run Master and the other as Slave, you DO NOT have to adjust ANY setting on the Slave amp corret? Also I have my subs inverted so should the phase control be turned to 180? I wired the subs as if they were installed normally.
On 4 HDC3 18's on two of these Candence amps I hit a 150.2 @ 36hz....I Should be louder :( granted that was running the subs about 4 hours after they were installed so there was no break in.
Also when i set the gain on the master amp, I disconected all the speaker wires from that amp put the oscope leads one in + and one in the - and played a 50Hz tone and set the gain to just under clipping. Does this sound right. When the speakers are actually wired to the amps it looks like the above diagram. Any help or suggestions would be great.
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
  • Who's Online   1 Member, 0 Anonymous, 1556 Guests (See full list)
