I have two Cadence C5 amps. I also have 4 AQ HDC3 18's D1. The amps instructions say 2 ohm final load when bridging the two amps.
So going by the instructions i take it that i can wire all four subs together down to 2 ohms then connect the positive wire to the positive on the Master amp and the negative to the positive on the Slave amp a wire from the negative of the Master to the negative on the Slave.
I am just wanting to make sure thats correct before i do it.
Edited by PUNKYOU007
d(-__-)b
beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home.
as long as you dont go below 2 ohms you should be good. remember when you strap those amps together its only 2 ohm stable
R.I.P '01 blazer you treated my ears well until your transmission blew up.
New Project
[top secret]
149.0 db on music driver window open; so close
I feel some boners are fueled by viagra and not true intimacy!......if you know what i mean....
I swear... sometimes I wish I was retarded so I could just agree with everyone x.
Yep. Although lol, they used the wrong terminal diagram in the manual. I don't know many C5's with a Left and Right Channel.
Use 2 runs of 8 gauge preferably to join the amp's negative terminals together.
10.x volts fo' life!
i didnt even notice that the two diagrams were different. the top amp goes Rem Neg Neg Pos Pos : the bottom amp goes Rem Pos Neg Pos Neg
so are you saying that i should run a wire from both negative spots on one amp to the negative spots on the other amp?
d(-__-)b
Correct :) That's what Sundown and many other manufacturers recommend. May as well minimise any loss between the amps.
what do you do with the other positive terminal? just leave it alone
i have never had amps like this before so im trying to learn this stuff before i get to installing them. Thanks for your help BTW.
d(-__-)b
Personally I use both positive terminals to go to brass bolts through the sides of the box. I would recommend doing the same, you're going to be shifting a fair bit of power so you may as well get some nice wire in there. A good way to do it is use a 4ga 'audio' lug and stick 2 runs of 8ga in it then crimp/solder it :)
So are the two negative terminals common points inside the amp? As well as the positive?
d(-__-)b
yeah its like a buss bar for the outputs
Team S.M.D.
Maritime Car Audio- (2) 18" SSA ZCON D1
- American Bass 500.1
- 60 ft of 3/0
-480 Ah of battery
- (2) stock alternators (70 +90)
- Kenwood Excelon x-794, 4v preouts
car audio is just a LOT more complicated than "this amp does this power" or "this sub will be this loud". its like 2 + 2 = banana. (if that confuses you then you get the point) lol
  • Who's Online   0 Members, 0 Anonymous, 445 Guests (See full list)
