Enclosure Build : Kicker CVX 15 "
Hey Members,
This is my 1st build log,
I initially got the design spec from the guys at kicker , with respect to tuning and air space for a slot port box. I had drawn it up on Cad, and it looked a bit ordinary, so I hit up Foreverbumpin for ideas on how to turn a good box into a great box. He recommended adding flares to the entrance and exits of the port.
Thank you Foreverbumping for your input. (You should be given MOD status for your contributions to this forum)
:drinks:
Heres my box design after numerous changes
I purchased the timber from our local guy, ( Im from South Africa) , Decided to go with plywood as its light, and I drive a vw polo hatch
I then plotted out the design with dimensions and so on ( metric units)
I then marked out the box walls and the port on the base and the top. All worked out well there with the wood being cut right.
I had to visit my uncle reggie thereafter as he had a table saw , which made life much easier, when cutting the kerfed parts, and has skill with kerfs.
The first roadblock I came across was the plywood grain was parallel to the kerf bend, meaning it would snap along the grain. We then decided to go with MDF for the kerfed parts. It bent easily with i bit of wetting on the face.
The following are pics of asssembly after cutting the kerfs.
my motto: hit it, quit it, never admit it :D
In the following Pic you'll notice the bend forma which we clamped screwed and glued the kerf to , to maintain the radius.
I added some additional bracing to the kerf as shown
The inner baffle :-) and the Big Boy
The double baffle in place
The enclosure about 70% done
My version of 45 s using strips of masonite board lol, I wasnt to concerned about rigidity as I was going to glass the inside of the box.
Bracing added for good measure
Wood filler over the 45s and gaps
I used UPVc pipe to create the inner port flare . I added ply wood forma to the back of it to provide support and prevent flex,
Test fit , All Good
Almost there, with sanding and filling , Shew! hard work for my limited skill and tools lol
Staring down the port, My hand couldnt fit down there , but I tried to do the best I could wrt sanding.
My first time glassing, and it wasnt very pleasant lol
I resined the outside of the port to strengthen it.
Test fit :-)just some sanding to go there after
The Bass is nothing close to what I expected, The gains on this box is awesome and is worth the extra effort, Im really impressed to say the least. It picks up a wide range of notes and is not sloppy, hits nice and hard. That 15 really comes alive in this box :clapping: .
I ll be planning on two tone leather to neaten up the box, but im still not sure on finishes. will keep you guys updated, It took me 4 weekends to get this far as well as some weekdays lol.
Thanks for looking
wow,
looks like a job well done.
2004 Yellow F150 STX 4x4 Single Cab
2 Yellow DC Power 270SP's Alts
4(and counting) XS Power 6500's
4 DD3515s Supercharged
53cu.ft 4th order blowthrough
8 DD M1b's
6 Selenium 8's
2 Selenium ST350s
154.1 @ 41hz Legal Burp
Build Log
very good work man,
leather or vinyl would look very sexy with that box
Loveing the port, only thing I would change would be how you done the inner corners of it. Outward cuves add bracing but roughen up the air flow. Shoulda done concave bracing there and not convex.
Anywho, AWESOME work, can't wait to see it covered and see some videos!
nice lookin box bro
and ur glassing is not as bad as mine lol
________________________________________________________________________
deepsilencer, on 22 Aug 2011 - 17:32, said:
splzx3, on 22 Aug 2011 - 17:27, said:
i had my fun on one of his videos...till he blocked me then i got my mother into it lol after her he closed the comments xD
WTF, I never thought I'd have a conversation about cross dressers and trans-genders on a car audio forum.
Thanks guys,
Appreciate the feedback,
Hey Glassing is messed up, especially when you run out of gloves lol,
@ Sanitarium , Thanks for the input, ah i get you , I was getting lazy for those one s :noob: although i think i can fix it by filling up the gap between and making them flatter.
I ll do a vid of the flex soon :-)
Just a quick update,
I just got done re doing the big 3 in my car with 1/0 guage knuknoceptz cable, and started cleaning up the box
Sanding...
Sanding...
And more Sanding...
Surface is Good enough for primer and flexstone on the Port
