so i was wondering if id need to fuze it since its just a 4g wire, ?
Why does wire size matter? So I guess all those little wires that make your vehicle run shouldn't need fuses either since they are small LOL..
TDH FTW !!!
yeah. the wire would burn up before the fuse would.
kind of defeats the purpose unless it's a small fuse...
yet your car runs fine with the stock 8-10 gauge and not burn up weird hey
as for OP dont use long nut for your battery get some aluminum and make a buss bar
101_0711.jpg?t=1269644570
and if you've got alot of 4 gauge laying around just use 2 runs of it
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
better yet.. move from side post to top post... just ditch side post altogether...
like i did.. i moved from GM sidepost to top post
and as far as the fusing question goes i thought he meant he was gonna fuse from the alt to the battery on 4 gauge. I think i hit the wrong reply button.
