i have 4 12's running off 2 different amps how to i hook up rca's to two amps is there a adapter to add another set of rca cables or what?
the easiest way is rca "Y" adapters
sony m60ui
polk mid/hi's
infinity 6000m on tower
fosgate p3d212 x2
fosgate p400-4
fosgate t1000-1bd
im ona boat bitch
My boat build
funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail :)
Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
ok thanks, i wanted to make sure of what to get.
thanks,robbie
usually you don't lose that much voltage using 1 y adapter ... you're not gonna need a line driver. I've done a couple setups with 2 amps, a y-adapter, and a 2v preout HU and it was fine. just make sure to set your gains with both amps plugged in.
1 amp is 1100watt mono-block and 2nd is 250 mono-block
... okay.... well .. that wasn't needed information... just do what I said. It doesn't matter what the amps are, it just matters that they're plugged in.
next time name your thread besides help
NoFearX18 said:
chode i think he did? or did you go and change that O.o /confused
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
  • Who's Online   1 Member, 0 Anonymous, 1365 Guests (See full list)
