Fi BL 18inch for sale!
1. Product:
Fi BL 18 inch woofer.
This woofer was used for a very short period of time at 2007 world finals (iirc) with a Kicker 2500.1 wired at 1ohm per woofer.
Dual 2 ohm coils that read 1.7-1.8 on a TRUE RMS clamp meter.
Woofer has the added Flatwind voice coil to handle more power and dissipate heat better.
2. Specs:
DUAL 2
Fs: 33.2 Hz
Re: 1.4 Ohms/coil
Qms: 5.82
Qes: .32
Qts: .30
Mms: 302g
Cms: 0.88mm/N
Sd: 1210cm^2
Vas: 181.0
Spl: 94.1dB 1W/1m
Bl: 22.7 N/A
Xmax: 18mm
Rms: 1000W
Sealed box: N/A cuft
Ported box: 5-8cuft
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 9.750”
Displacement: 0.26cuft
3. Description/Condition:
Woofer is sold without the rubber gasket. From what I remember the wall baffles wouldnt allow the woofer to be flushed in with the rubber gasket. It was removed and MIA.
Again used for a very short period of time at world finals 2007, then uninstalled.
The woofer is still pretty stiff.
Slight rubbing on the pads located on the cone, none on the spiders.
Tinsels appear to be in great condition with no loose frays or discoloring.
No cuts or tears in the surround or cone.
Voice coil also is in great condition, no discoloring, no rubbing.
4. Price:
Looking for $250 SHIPPED in a wooden crate which I still need to make.
Im also open to some offers, but NO LOW BALLS!
NO TRADES WHAT SO EVER!
If local buyer (depending on location) I will drive a bit to hand deliver or meet up. If this is the case I will reduce price due to no shipping being done.
Im pretty well known through out WI and IL in the competition seen, and have all perfect refs on SMD and CACO!
5. Pictures:
** DO NOT DELETE ANYTHING BELOW THIS LINE OR THREAD WILL BE DELETED **
This message is automatically inserted in all classified threads.
Please be advised, all buyers and sellers should satisfy themselves that the other party is genuine by providing the following via PM to each other after negotiations are complete and prior to dispatching goods and making payment:
1) Telephone number. Call the number back at a unspecified time and make sure that it is the person's correct phone number.
2) Name and address including postal code
3) Valid e-mail address. Send an e-mail requesting a response to information about the deal being made.
DO NOT proceed with a deal until you are completely satisfied with all details being correct. It's in your best interest to check out these details yourself.
If transaction was completed on CACO, please use iTrader to record feedback.
Potential buyers/seller should check iTrader feedback also before continuing transaction.
Lol. Awesome guy here! GL B. Didnt know you had this laying around!
04 Chrysler Sebring
Stinger
C&D Technologies
Alpine
Infinity/cdt
Zapco
TC Sounds custom subs
my bud is very interested in this just told him about it and he said if you still have it when he is off work he'll try to buy it
1995 Honda Accord Coupe
still building only thing done is big three and one run of stinger 0 gauge.
Feedback
1. Product:
2. Specs:
DUAL 2
Fs: 33.2 Hz
Re: 1.4 Ohms/coil
Qms: 5.82
Qes: .32
Qts: .30
Mms: 302g
Cms: 0.88mm/N
Sd: 1210cm^2
Vas: 181.0
Spl: 94.1dB 1W/1m
Bl: 22.7 N/A
Xmax: 18mm
Rms: 1000W
Ported box: 5-8cuft
Sub OD: 18.500”
Cut ID: 16.750”
4. Price:
Im pretty well known through out WI and IL in the competition seen, and have all perfect refs on SMD, PWK, and CACO!
5. Pictures:
