white4d96 Posted March 29, 2010 Report Posted March 29, 2010 I have an eBay HID set installed on my low beams. Whenever I switch them on I get alt noise through my speakers. Do I need relays, or is there another issue? Quote Too many projects, too little time...
BeAlLsTaR13 Posted March 29, 2010 Report Posted March 29, 2010 I have an eBay HID set installed on my low beams. Whenever I switch them on I get alt noise through my speakers. Do I need relays, or is there another issue? sure its alt noise? dos it make just a pop sound when you turn them on? thats normal my guess if its constant you have a ground issue somewhere... Quote Team Sundown Audio**CURRENT** -- 2012 Scion tC Build Click Here **OLD** -- 2002 Pontiac Grand AM Build Click Herecheck them out, slap me a comment2002 Pontiac Grand AM SE 2.2l 4 cylinder ecotec.-------------------------------------------------------------------Head Unit - Alpine CDA-9887Subs - 2x Z 12 v.2s - v.3 + NS Soft partsAmplifier - Sundown Audio SAZ-3500DEnclosure - 3.33 Cubes tuned to 34.66hzFront Stage - JBL P660c 6.5" ComponentsRear Deck - Powerbass 4xl 6.5" Mid-RangeFront Stage Amplifier - Sundown Audio SAX-100.4DWires - Kicker Hyperflex 1/0, KnuKonceptz 1/0, Knu 4 and 8 Gauge, Kicker RCAsElectrical - 275 AMP DC Power H/O Alternator, XS Power S3400, XS Power D2700Videos - http://www.youtube.com/user/BeAILsTaR13-------------------------------------------------------------------
Alexdb7 Posted March 29, 2010 Report Posted March 29, 2010 yeah check your grounds bud Quote Custom Car Audio (815) 916 - 9194 www.midwestsplcustoms.com 2000 Tahoe | 22" GREED Celebrities Alpine CDA-117 Dual 0/1 Runs (3) 925 CA Group 31 In Back (4) 18" FI Audio Q's (W/ Extra Spider) (4) Hifonics BXi 2010D Hifonics ZXi 4410 4 RF P1653 6 1/2's Big 3 All Kicker/Knu Wiring
white4d96 Posted March 29, 2010 Author Report Posted March 29, 2010 Amp grounds are clean and tight. Whether they are bolted to a good spot may be debatable, but I've been at a loss since I have a unibody car, so I just bolted it to the spare tire well (after grinding the paint and primer off of course.) But it is definitely alt noise, as it ramps up with engine speed. It also occurs only when the headlamps are on, if that means anything. I will check my batt-chassis ground and see if it needs cleaning. If that isn't the case, then I guess I'll have to try moving my grounds. Quote Too many projects, too little time...
