lownslow336 Posted March 29, 2010 Report Share Posted March 29, 2010 okayy so pretty much my car is stock as far as electrical..stock alt you knw the rest i have a RF500.2 pushin a 15' CVR, 2ohms each coil sometimes it will hit really hard an then sometimes it doesnt an it likes to cut off as well wen i turn the bass knob up.. idk...my gain isnt really up, no more than half way idk..any ideas? Jenson head unit Rockford Fosgate wiring Rockford Fosgate p200.2(mids/highs) Rockford Fosgate p500.2(subs) 15' kicker L7 Link to comment Share on other sites More sharing options...
Sanitarium Posted March 29, 2010 Report Share Posted March 29, 2010 what's the electrical system look like? where did you ground the amp? Have you tried using a different set of signal wires (rca) ? Link to comment Share on other sites More sharing options...
lownslow336 Posted March 29, 2010 Author Report Share Posted March 29, 2010 what's the electrical system look like? where did you ground the amp? Have you tried using a different set of signal wires (rca) ? its grounded to the bottom of my trunk..the ground is good i knww.. an i have some radio shack rca's..an some other brand..i need to upgrade them lol Jenson head unit Rockford Fosgate wiring Rockford Fosgate p200.2(mids/highs) Rockford Fosgate p500.2(subs) 15' kicker L7 Link to comment Share on other sites More sharing options...
jagblazer01 Posted March 29, 2010 Report Share Posted March 29, 2010 is it going into protect or is it just cutting out?? I would check your connections personally. I dont believe that amps draws a ton of current Team Sundown Audio / Team XS Power / Team SHOK SMD Super Buyer/Sellerwww.sundownaudio.com www.shokindustries.com www.4xspower.com www.excessiveamperage.com Link to comment Share on other sites More sharing options...
ISO Posted March 29, 2010 Report Share Posted March 29, 2010 If its a Punch amp and its wired to 2 ohm then its going into protection. 4 ohm bridged only. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
PUNKYOU007 Posted March 29, 2010 Report Share Posted March 29, 2010 I would say double check your ground. I know you said its good but it might not be as good as you think it is. Doethepaperboy "Bars of Pain" Doethepaperboy "Hero Remix" C. Arson d(-__-)b beer sucks...but i can bring some jose cuervo. Only problem is that it makes me horny and gives me the rams. So unless yall wanna fight and then have some great make up sex i will leave it home. Link to comment Share on other sites More sharing options...
ISO Posted March 29, 2010 Report Share Posted March 29, 2010 LOL I have this weird shitty feeling that you have one coil going to one channel and the other coil going to the other channel for a 2 ohm load to each channel. That is wrong and if thats the case then your amplified coils are getting conflicting signals = BAD. Isobaric - Refers to the practice of coupling two drivers together to make them act as one. "Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go." Insanity: doing the same thing over and over again and expecting different results. The Destruction of a person builds character. Link to comment Share on other sites More sharing options...
lownslow336 Posted March 29, 2010 Author Report Share Posted March 29, 2010 LOL I have this weird shitty feeling that you have one coil going to one channel and the other coil going to the other channel for a 2 ohm load to each channel. That is wrong and if thats the case then your amplified coils are getting conflicting signals = BAD. yeaa your shitty feeling is rightt haha Jenson head unit Rockford Fosgate wiring Rockford Fosgate p200.2(mids/highs) Rockford Fosgate p500.2(subs) 15' kicker L7 Link to comment Share on other sites More sharing options...
lownslow336 Posted March 29, 2010 Author Report Share Posted March 29, 2010 yeaa your shitty feeling is rightt haha but its a dual 2 ohm Voice coil...shouldnt matter right? Jenson head unit Rockford Fosgate wiring Rockford Fosgate p200.2(mids/highs) Rockford Fosgate p500.2(subs) 15' kicker L7 Link to comment Share on other sites More sharing options...
L8-NiTe Posted March 29, 2010 Report Share Posted March 29, 2010 Take the positive terminal of one coil and run a short wire to the negative terminal on the other coil.Take the remaining positive and negative(one from each coil that has no wire hooked to it) and run those to the amp.4 ohms now. Link to comment Share on other sites More sharing options...
