Fi Car Audio
was wondering if a single 15"bl fully loaded could handle (2) audioque 1200d's one on each coil? its a d2
also considering getting second BL and using 2 audioque 1200d's strapped 3700x1 @2OHMS...????
i dont recommend using one amp per coild because tunning the amps to the exact same output level is near impossible which is not good to have coils at diff power levels. But could a single bl take 2 aq 1200's im sure it could if your smart with it of course dont clip the amps and have a properly built box and you should be good. I have a AQ 2200 on a single 15" Q with bp power and its fine
Johns.jpgSuburban Coming Soon
FYI, you won't get 3700rms with the AQs strapped at 2ohms. And there is no way the BL will take 3700rms if you did get a different amp. Check out the AQ2200...
12" DC LVL 4
Sundown 1200D
PG RSDs
PPI PC2100
Alpine 9886
Posted 29 March 2010 - 02:40 PM
it's not recommended to run more than 2000 watts on 1 Fi BL
  • Who's Online   0 Members, 0 Anonymous, 1661 Guests (See full list)
