Up for sale is an American Bass SQ440. I purchased this from a friend because I thought that I could use it but I cant. Im Looking for $30 (what i paid for it) + shipping. It is a four channel amp. 6/10 Cosmetic. 9/10 Mechanical. The only things that is wrong 'mechanically' is a couple of terminal screw are missing. Looking for something that will put out 200 watts rms at 4ohms. It can be mono or two-channel. If you have one, I can put up cash on my side too.
RMS @ 2 Ohm, Stereo: 70W x 4 Ch.
RMS @ 4 Ohm, Stereo: 50W x 4 Ch.
RMS @ 2 Ohm, Mono: 125W x 2 Ch.
RMS @ 4 Ohm, Mono: 100W x 2 Ch.
S/N Ratio: >100dB
THD (IHF-A): 0.02%
Channel Separation: >55dB
Input Sensitivity: 0.15V – 5V
Input Impedance: 47K Ohm
Slew Rate: 10V/Usec
Damping Factor: 200 @ 4 Ohm
Fuse Rating: 20A x 2
Dimensions (in inches):
Width: 9.54"
Height: 2.13"
Length: 11.02"
Features
# MOSFET Power Supply Amplifier
# Gold Plated Brass Screw Set Terminals
# 12dB/Oct. Crossover - Variable High Pass Crossover (30Hz ~ 500Hz) - Variable Low Pass Crossover (30Hz ~ 500Hz)
# High/Low Level RCA Inputs
# 5-Way Protections
# Power and Protection LED Indicators
# 2 Ohm Stable Circuits
# Soft Start/Mute Circuit
# Tri-Mode Output Configurations
Edited by bcpballer64
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
do you have any specs on this amp? the American bass web site isn't working for me
I found these specs.
S/N Ratio: >100dB
THD (IHF-A): 0.02%
Slew Rate: 10V/Usec
Width: 9.54"
Height: 2.13"
Length: 11.02"
Features
# 5-Way Protections
Which as far as i know are accurate.
I will take it, send me a pm with final price including shipping to 64060
1999 Chevy Tahoe
Level 4 15"
AP 3000d
Rockford and Phoenix Gold Componets
T400.2
Mechman 250 amp Rhino
2 Kinetik 2400
GET LOUD : STAY LOUD : SLAP RESPONSIBLY
Sold to H816*John*H816.
This topic is now closed to further replies.
