kogwanted Posted April 1, 2010 Report Posted April 1, 2010 hey guys i just got everything i needed for my system and i was wiring it all to one ohm and i came out with my speaker wire with a positive and a negative that would lead to my amp of course. but there is 4 spots to put the speaker wire 2 + and 2- so.... does it matter or is there some special way and i was also wandering what i should set all the levels on the amp i have a sundown 1200d and 2 12'' alpine type rs let me know and dont make fun of me its a learning experience thanks
kl0wn Posted April 1, 2010 Report Posted April 1, 2010 You have 2 set of +/- terminals to make wiring the subs easier. You can wire the 2 subs together with just 1 set of +/- terminals, and it'll be the same as wiring them both with the 2 sets, they're just there to make the wiring easier. About knowing where to turn the gain, use an O-Scope so you know you are not clipping. If you do not have one or cannot get your hands on one, you can use a DMM. How To Set Your Gain With DMM 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz
devil4u2c Posted April 1, 2010 Report Posted April 1, 2010 it depends on how you are wiring them up. If you are running the amp bridged then you would use the outer pos and neg.
kogwanted Posted April 1, 2010 Author Report Posted April 1, 2010 You have 2 set of +/- terminals to make wiring the subs easier. You can wire the 2 subs together with just 1 set of +/- terminals, and it'll be the same as wiring them both with the 2 sets, they're just there to make the wiring easier. About knowing where to turn the gain, use an O-Scope so you know you are not clipping. If you do not have one or cannot get your hands on one, you can use a DMM. How To Set Your Gain With DMM not only that i mean with the subsonic and the bass boost and all that stuff i havent messed with much of that kind of stuff
devil4u2c Posted April 1, 2010 Report Posted April 1, 2010 That is why he was talking about an o-scope. You have to set the gains so that you minimize clipping, you use an o-scope to do so.
devil4u2c Posted April 1, 2010 Report Posted April 1, 2010 the sub sonic is your crossover point, usually set to however your box is tuned
