az73 Posted April 1, 2010 Report Posted April 1, 2010 so going for a ripple trick in the boat saturday. done everything i know to the best of my ability.even downloaded some "Decaf".reread how to set gains again and think i understand it. so go across town to hanger, to boat and do all my step and its a t1000-1bd that tested out @1390 watts. the gain is at 7 of 11 and volume was at 40 of 60. sub knob maxed as to set for highest and never go passed it. 66.7x66.7=4448.89 divided by 2ohms =2224 watts where did i f up sony m60ui polk mid/hi's infinity 6000m on tower fosgate p3d212 x2 fosgate p400-4 fosgate t1000-1bd im ona boat bitch My boat build funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
t-money Posted April 1, 2010 Report Posted April 1, 2010 is the loud turned off and eq set to flat? 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
P4killer_ Posted April 1, 2010 Report Posted April 1, 2010 It's wattage times ohms. Sqrt of that equals ac voltage So (1390*1ohm) = 1390 √1390= 37.28 is what your dmm should read. Also I have the same dmm make sure the ac/dc button in the upper left is pushed in iirc for ac because. It reads all crazy if not at least on my dmm (same one you have) I just set my gains with that dmm they same way like 2. Days ago Edit my phone puts Emma instead of dmm. Yea loud off equilozer set to flat Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
t-money Posted April 1, 2010 Report Posted April 1, 2010 so going for a ripple trick in the boat saturday. done everything i know to the best of my ability.even downloaded some "Decaf".reread how to set gains again and think i understand it. so go across town to hanger, to boat and do all my step and its a t1000-1bd that tested out @1390 watts. the gain is at 7 of 11 and volume was at 40 of 60. sub knob maxed as to set for highest and never go passed it. 66.7x66.7=4448.89 divided by 2ohms =2224 watts where did i f up i have a chart that is already worked out as to what your dmm should read if u want it 2002 ford focus hatch pioneer DEH-P8400bh infinity kappa 6.5 components front and rear XS Power D1200 Shuriken BT-100 audioque 120.4 2 15 inch audioque HDC3 D2 2 audioque 2200d big 3 mechman 220a alt with external regulator 479-418-3056
az73 Posted April 1, 2010 Author Report Posted April 1, 2010 yes it was on a/c. the chart is in a link in the topic below " worlds worst noob question". so am i to assume its ok for dmm to read that but i need to set the gain down to 37.8 actually 52.9 @ 2 ohm=1400 sony m60ui polk mid/hi's infinity 6000m on tower fosgate p3d212 x2 fosgate p400-4 fosgate t1000-1bd im ona boat bitch My boat build funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
P4killer_ Posted April 1, 2010 Report Posted April 1, 2010 You take your wattage multiply that by your ohms. Take the square root of the number you get from above That's what the dmm needs to read. Make sure all loud is off equilizer is flat aka all at 0. So for instance your amp does 1390 at one ohm. So 1390 x 1 is 1390. The sqrt of 1390 is 37.28... So if your setting your amp at one ohm to do 1390w that's what you do. But if your at 2 ohm that's changes things and you have to redo the math. Only takes a sec Hope this helps Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
P4killer_ Posted April 1, 2010 Report Posted April 1, 2010 Yea 52.9 @2 ohm is 1400 if you reverse the math. So yea you got it down pat. Now set yo gain Foo Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
P4killer_ Posted April 1, 2010 Report Posted April 1, 2010 Plug the leads into the speaker terminals make sure speakers are un plugged. 50hz tone in the cd player settings flat. Turn gain till you get desired ac voltage .your done Setup: 2010 Hyundai Elantra Factory Unit via 4 chan NVX LOC Excessive Amperage "H/O" Alt Xs D3400/ Xs XP3000 Big 3. 2 Runs of +, 2 Runs of - DD M3b and 2 12" AQ HDC4s
az73 Posted April 1, 2010 Author Report Posted April 1, 2010 kkkkkkkkkooooooouuuuuuuulllllllll thx guys.... amazing how simple something is a how your brain can just "F" it until.....ding .... light bulb comes on. sony m60ui polk mid/hi's infinity 6000m on tower fosgate p3d212 x2 fosgate p400-4 fosgate t1000-1bd im ona boat bitch My boat build funny thing is...............slamming fireworks in to the ground with a sledge hammer in mexico is like car audio in california... everyone is doing it but most fail Every time I read a comment you post, or a topic you make... I cannot help to think of how much of a badass you are!!
