Guest MegaloManiac Posted June 24, 2007 Report Posted June 24, 2007 My Starter is going out on my 00 Honda Accord LX sdn 2.3L vtech. I can tell cause when i try to start my car it takes forever for it to crank. Anybody have a good tutorial on how to change it out myself? My cousin knows how to do it but he said to get a tutorial just to be sure, he's only done it on a maxima. All help would appreciated. Also Autozone prices reasonable? I think its around $100-$150 for a new starter plus if you bring the old one back they give you money for it. Quote
Coolwazabi Posted June 24, 2007 Report Posted June 24, 2007 maybe its the coil or the disto cap... Quote
Guest MegaloManiac Posted June 24, 2007 Report Posted June 24, 2007 Is there a way to identify if its that? Quote
AI James Posted June 24, 2007 Report Posted June 24, 2007 coil and distro should been changed last tuneup, i change mine with tuneups guess its just somethign extra i do. Quote
Coolwazabi Posted June 24, 2007 Report Posted June 24, 2007 look at the disturbtor and see if there is any carbon build up or piece of soot like material... and the coil... not sure but mine was the wire was all burned up... just look for anything obvious that doesn't look safe/good... i think if the starter went out... it wouldn't start... period ! Quote
AI James Posted June 24, 2007 Report Posted June 24, 2007 look at the disturbtor and see if there is any carbon build up or piece of soot like material... and the coil... not sure but mine was the wire was all burned up... just look for anything obvious that doesn't look safe/good...i think if the starter went out... it wouldn't start... period ! starter can be going out and it start sometime and sometimes it not, mine on my accord before it went out, i tapped it with a wrench many times before it finally totally went kapput Quote
Coolwazabi Posted June 24, 2007 Report Posted June 24, 2007 starter can be going out and it start sometime and sometimes it not, mine on my accord before it went out, i tapped it with a wrench many times before it finally totally went kapput hmmm... kapput eh ? idk... i'd say check your coil and cap before you change your starter.. might save a lil $$$$$$$ Quote
Coolwazabi Posted June 25, 2007 Report Posted June 25, 2007 wow... someone is takin my advice... sweeeet... Quote
philip Posted June 25, 2007 Report Posted June 25, 2007 isn't the coil internal on that car? also if it's cranking, then the starter is working. if you turn the key and nothing, then maybe starter. if you have to hit the starter, then yah starter. i would first check your voltage when you're cranking ansd see what it is. if it goes below say 8v, try hook up a pack or a battery charger and see if it starts faster. if it does, change the battery. just my 2 cents. Quote
