Ok guys i needs your help, i am trying to figure what is the best way to take apart without breaking a 78 turn signal to clean it and freshen up, And what is the best way to put them back together. I can post pics up if needed.
-Thanks in Advance, David
...............................____
...............__________|___\____
..;.;;.:;:;.,;.|__(O)____|____/_(O)
1978 F-150 Ranger Lariat
2 Sets of Sound-stream Components
Sony Head-unit
DDM Tuning 8000k's
Euro Headlights (Projectors Soon)
Green Led Wheel Wells
Dark Red Tails Tint
yeah, i wanna take them apart and paint the tan part high gloss silver and clean the lens up a bit,
Sony Head-unit
DDM Tuning 8000k's
Dark Red Tails Tint
The best and easiest way is to put them in the oven for a few minutes at around 350 degrees or so and then it will warm them up the glue enough to pull them apart.
"WHOEVER SAID MONEY CAN'T BUY HAPPINESS MUST OF BEEN BROKE"
Its okay to do this to a 30 year old part lol.
Sony Head-unit
DDM Tuning 8000k's
Dark Red Tails Tint
Just make sure when you put it back together, you make sure everything is 100% right, put it back into the oven, let it heat up and seal it back up.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
Look around on the internet but ive seen it done in a magazine im thinking truckin' and they did it to a older truck for the headlight assembly so the could have a clear lens and do projection headlights. ill look around but all you need to do is heat it up enough for the glue to seperate, even a heat gun would probably work good enough.
Ok im really convinced thanks alot guys for the help, and if you can find that you were talking about please show me. And i will look for it aswell.
Edited by David78
Sony Head-unit
DDM Tuning 8000k's
Dark Red Tails Tint
http://forums.evolutionm.net/lancer-how-requests-questions-tips/130062-diy-black-headlight-housing-update-pics.html
Heres something that you can look at for help
EDIT: and ive also seen people use a piece of plexiglass and made their own clear lens for it and put it back on and it looks alot better
Edited by David711
thats the way Ive done my past two sets of headlights, heat the edge and pry with a flat head screwdriver VERY slowly and its should come apart.
Hope you dont mind me adding a pic.... :pardon:
