i would like to build a ground pounder with either 2 or 4 12" DC lvl 5 subs. for the amp i was thinking of using some alpine MRP M2000 rated at 2000 rms at 2 ohms, its a mono amp. if i hook up 2 dc's to it rated at 2 ohms total does the amp still put out 2000 rms to each sub. or should i go with a different amp all together. any and all feed back is welcome.
If you do those 2 subs and that amp by itself, you will need the subs to be 2 ohm DVCs, and you'll wire the voice coils in series which will give you a final load of 2 ohms, which will push 1,000 RMS to each sub.
If you want 2,000 RMS to each sub, you would have to get the subs in 1 ohm DVCs, and wire 1 amp to 1 sub with the voice coils in series, and do the same for the other amp/sub. That will give you a final load of 2 ohm for each sub, which then will push 2,000 RMS to each sub.
06 Mini Cooper S
Sundown, SoundQubed
Cadence, XS Power
151s Sealed
155s Outlaw
Windshield @ 37hz
If you want 2,000 RMS to each sub, you would have to get another alpine mrp m2000, and get the subs in 1 ohm DVCs, and wire 1 amp to 1 sub with the voice coils in series, and do the same for the other amp/sub. That will give you a final load of 2 ohm for each sub, which then will push 2,000 RMS to each sub.
fixed
2006 F-150
XS Power
4 DC 3.5kw
Team DC
Team S.P.L.
Lot of Audio Technix and 1/0
DC Audio Dealer
American Bass Dealer
XS Power Dealer
Audio Technix Dealer
  • 4 months later...
Are you also planning on upgrading later? If your only running 1000wrms (or even 2000) why go with the lvl 5? I would say stick with the lvl 5 but get a bit more power. :) I have lvl 4xls and love them on over 4k. I just heard it takes a lot o power to really get the lvl 5 moving.
Edit: wow. I just realized these posts were from April. My bad
Edited by herbykw
06 300C 5.7 Hemi
K&N CAI
JVC KW-AVX640 6.1" DVD
DC Audio 3.5k
6 DC Audio 8"s
6 cubes 8" aero port at 32hrtz
http://www.stevemeadedesigns.com/board/topic/183798-chrysler-300c-8-build/?p=2731834#entry2731834
