Well just looked thru 16pages and well I am pretty damn impressed! :D GJ team it up :drinks:
Team Subsonic Lows
Get your garbage EMF products of my amp bitch
Man....it makes a nice work bench ;)
Helper springs sit ontop of your current leaf spring pack and are bolted around them and as PHD said, they spread out the spring. Another option like Blue said is to do the air bags but that can get pricey and it's a pain to put in the bag cups if you need to do serious modification. One option that I did with my Ranger to help with trailer weight is to get a set of load adjusting shocks. These shocks are a direct bolt-in where your factory rear shocks are currently. The load adjusters are a coil over shock capable of helping the truck handle an extra 1200 lbs of weight over the leaf spring's factory ability. As you add weight to the truck, in this case your 40 cubes of insanity, the coil-overs push back and distribute the load better. You can probably get a pair for around $120 at your local auto parts place, i'll take a look when i go into work later and see if i have a listing and i'll get you a part number.
DC SOUND LAB NUT HUGGER
Currently Own
4 - 18" lvl 6s (m3) w/full Carbon Fiber option
2 - DC 5k
lvl 4 motor
lvl 2 motor
On 8/2/2013 at 8:13 PM, n8ball2013 said:
this is much worse. Its old n8 without the time or patience to hold fucking hands. I'm supposed to be doing school work but yet here i am making sure jr fuck fuck isn't trying to poke the other kids with a stick.
Alright so since i have no life, i called my store and asked for some information on the shocks for your truck. Now my computers have been wrong before but it says that you have strut assemblies on all 4 corners of your truck, is that true or do you have leaf springs on the back?
Currently Own
2 - DC 5k
lvl 4 motor
lvl 2 motor
Any new progress?
Yep, very little though lol.
Thanks
Great build you have going on here. Quick question though, do you have springs on the rear or do you have air bags? Guessing springs due to the rear end sagging. Might want to think about putting air springs with pumps and an air tank. The Expeditions came stock with rear air ride. Could try to swap out the rear springs with the bags and do it that way. With the air, it will support the weight easier and provide a better ride.
Thanks. I have springs in the back. Idk if I would have would for an air tank anywhere lol, I'll have to look.
I'm not too sure, I'll have to check tomorrow. Thanks for all of the info you, and a few others, have gotten me on the suspension stuff.
It's been a while since I've done any work, but I did get a lil done today before going kayak fishing.
Made life a lil easier.
Nice tight fit.
When I took this pic, I realized that I went a lil overboard with the glue lol.
Screwed
Circles for hole cutouts, decided to use a screw instead of a pensil for some reason lol.
I'll hopefully get a lil more done tomorrow after riding and before fishing again. Gotta get out and get some more fiberglass too.
Rest of the layers cut, just gotta cut holes out. The jig saw overheated half way through the first hole, so I'll be finishing that tomorrow lol.
First two layers glued and screwed.
I may end up doing another .75" baffle/beauty panel all in one piece and mount the subs to that, then do a layer of .5" to recess the subs. Making the baffle thickness a total of 5".
