robbie Posted April 10, 2010 Report Posted April 10, 2010 i have a Schoshe 500k micro farad cap i havn't hooked up one like this before it only has one terminal for + & - so how would i hook this up from battery to amp with only one terminal for + ? and will this work with a 1100watt mono-block amp?
newls1 Posted April 10, 2010 Report Posted April 10, 2010 hooking up a "cap" is just like wiring a battery. That cap isn't going to do a damn thing for ya though....... I love my staffie So anti FACEBOOK it isn't even funny
raytard Posted April 10, 2010 Report Posted April 10, 2010 throw it out. not really gonna do much for you... but basically you just run it in parallel... Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
blackrosetiger Posted April 10, 2010 Report Posted April 10, 2010 i have a Schoshe 500k micro farad cap i havn't hooked up one like this before it only has one terminal for + & - so how would i hook this up from battery to amp with only one terminal for + ? and will this work with a 1100watt mono-block amp? as far as hooking up to your battery/amp they're called ring terminals try them sometime they work great lol jp BUT if your electrical is done right you don't need a cap unless you have 0 voltage drop then all its goning to do is smooth it out 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
robbie Posted April 10, 2010 Author Report Posted April 10, 2010 well it was free so yeah i'm not out any money on it, so what could i do to keep my volts up i have 4 12's 2 amps 1100watt and a 400watt
blackrosetiger Posted April 10, 2010 Report Posted April 10, 2010 what amps and what 12's? and what gauge wire do you have run to them? big 3 in 1/0 gauge? what are you running for a battery? what is the amperage on your alt? (Im assuming its stock)Are your wires crimped or soldered? 1998 Plymouth Voyager (daily) Jensen VM9213 H.U. (I Know but I havent had any problems.... yet) 5.25" Factory -> Sound Stream SST5.2 6x9 Hifonics ZXi 693 -> Sound Stream SST6.9 Amp: Class D: Crescendo 3KWP (x2) Class A/B: Crescendo 1000C4 Sub: Almani S-7 10" (x6)
newls1 Posted April 10, 2010 Report Posted April 10, 2010 well it was free so yeah i'm not out any money on it, so what could i do to keep my volts up i have 4 12's 2 amps 1100watt and a 400watt your kidding right? were u really thinking that "CAP" was going to do anything for you? want to keep volts up, an additional battery first, then a HO alt.....problem solved I love my staffie So anti FACEBOOK it isn't even funny
kmalinich Posted April 10, 2010 Report Posted April 10, 2010 your kidding right? were u really thinking that "CAP" was going to do anything for you? want to keep volts up, an additional battery first, then a HO alt.....problem solved x1000000
robbie Posted April 10, 2010 Author Report Posted April 10, 2010 honestly idk what i was gonna use the cap for and ive got another battery to go on it just havnt put it on yet
CaptainzPlanetz Posted April 11, 2010 Report Posted April 11, 2010 what amps and what 12's? and what gauge wire do you have run to them? big 3 in 1/0 gauge? what are you running for a battery? what is the amperage on your alt? (Im assuming its stock)Are your wires crimped or soldered? The bolded area below was copied from his build log, just to give you some info. 1990 gmc ext.cab s15 4.3 v6. Specs Battery & Alternator : Super Start premium & stock Alt. (going to add another battery and Alt. soon) Headunit: Jvc KD-s36 Subs & amps : 2 12in Sony Xplods on a 1100watt Sony xplod mono-block amp 2 12in MTX Terminator series on a 400watt mono-block amp ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
