alright so i finnaly decided to get rid of my prefab since i hate the port just looks dumb :P, anyways if anyone could draw up some box plans for me id appricate it, i cant really seem to find any dimentions for my "trunk" but eh dont think a box is gunna be 3 feet tall >.>, width wise ill mesure tom.
heres the specs of the subs, mind you theres 2
Fs (Hz) 38
Vas (cu ft) 4.017
Sensitivity 87.2dB
Mounting Hole Diameter (Inches) 10.91
Mounting Depth (Inches) 5.51
my gpa will be building it from 3/4 MDF if we can find some laying around that is, we owned a millwork for awile, but would say 1/2" MDF be ok? or just straight say....pine or oak? jw :P
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
dont do 1/2. 3/4 with wood dowel bracing will be fine.
says right here on crutchfield, ported box volume: 1.5 cubic ft.
so do a 3cuft box (after sub and port and bracing displacements) tuned to probably 34-35hz will be fine.
my gpas old, so he wants pure mesurements, cubic feet mean nothing to him lol, hes nearly 8 0 but hes a tough fucker
Edited by Freshman6969
you can figure that out yourself since i have absolutely no idea what your max specs are. plus its good that you learn now instead of later. find Torres (thats his username) calculator on here and play with settings.
Edited by Kranny
and really you dont have to worry about bracing its just 2 12's and i think those cobalts are the low end like 500w or something iirc, just a simple 2 12 box will do. Use the RE calculator, itll do everything for you even a cut sheet i think. just google RE box calculator or something :P
Setup:
2010 Hyundai Elantra
Factory Unit via 4 chan NVX LOC
Excessive Amperage "H/O" Alt
Xs D3400/ Xs XP3000
Big 3. 2 Runs of +, 2 Runs of -
DD M3b and 2 12" AQ HDC4s
yeah i dident think it needed bracing either, there 400watts about, but i just dont know where to start from
alright after a little looking around this is what im looking for design wise, cuz i have my subs up and port up as of now, it sounds a tad better on an angle, i proped it wile i was messing around one day
IMG]http://i748.photobucket.com/albums/xx127/freshman69699/hgfggfdfjj.jpg[/img]
bumpage
daily bump, looking for someone who can draw it out with mesurements, port can be changed around if need be, but im trying to stick with that design
nightly bump, ANYONE?!!?!?
