Having some problem with my caprice and the damn temp gauge. I thought it was the temp sensor "that normally fixes the issue" but it isn't. What else could it be ? I know the cable is still working because when I turn the car.. its flip all the way across the board and just sits at "C, COLD" and never moves. Suggestions ?noob.gif
so how do you know its not the temp sensor did you change it? have it checked? have you checked the wire to make sure the connection is good no breaks in the wire if all checks out you might have to replace the guage good luck
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
yeah i replaced the sensor.. since it was a cheap route and a quick fix... i don't think the wiring is the issue since nothing has happened with it lately ?? i guess it could have broke shrug.gif ?
its the only thing I can think of thats next to be the problem hit up the junkyard see if you can find a temp guage from another caprice or if you don't like used the dealership can get you one
big 3 1/0
  • 4 weeks later...
