victor8881 Posted April 12, 2010 Report Posted April 12, 2010 When does one need to upgrade to a HO alt? I'm running a AQ hdc 15 with a hifonics 1610d amp along with a four channel Hifonics. I have one shuriken 35ah battery in trunk stock starter battery, stock alt and at idle lowest I've seen voltages drop was 13.2 over 2000 rpm's I don't see drops lower than 13.8. Basic question is, when I start looking into a ho alt, and what should I be looking for as ampreages go? HU: Kenwood KDC-MP745U. Sub: AQ HDC 15 Amp: Hifonics BXi 1610D for sub, ZXi 6410 for mids highs Speakers: 6.5 premium MB Quarts components,6.5 MB Quart premium coaxial back doors Wiring: KLMX Kable 1/0g for Big 3.Double up 4g from battery to trunk...for now. Big 3: YUP! Battery: Shuriken SK-BT35 to the trunk. Randoms: Flush mounted Stinger blue digital voltmeter. Flush mounted Memphis 7band EQ- 16-EQ50. phoenix gold 2 channel line driver.
MrSkippyJ Posted April 12, 2010 Report Posted April 12, 2010 When does one need to upgrade to a HO alt? I'm running a AQ hdc 15 with a hifonics 1610d amp along with a four channel Hifonics. I have one shuriken 35ah battery in trunk stock starter battery, stock alt and at idle lowest I've seen voltages drop was 13.2 over 2000 rpm's I don't see drops lower than 13.8. Basic question is, when I start looking into a ho alt, and what should I be looking for as ampreages go? If you aren't seeing a drastic drop in your voltage, don't worry about upgrading alts. If you are staying about 13 volts at idle (with your system on and up) then you are fine. Unless of course you are running higher than a 12v system. But then you probably wouldn't be asking these questions F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
Guest Posted April 12, 2010 Report Posted April 12, 2010 when? when your volts start dropping past ~12 while driving why? to feed your car more power (aka amps) how much? depends on your system/what you plan on running
